Start (ns) End (ns) Duration (ns) DurChild (ns) DurNonChild (ns) Name PID TID Lvl NumChild RangeId ParentId RangeStack NameTree
13,456,656,229 13,462,758,642 6,102,413 0 6,102,413 Region 1 150,219 150,219 0 0 1 :1 Region 1
14,542,903,861 14,543,115,685 211,824 202,537 9,287 aten::to, op_id = 1 150,219 150,219 0 1 2 :2 aten::to, op_id = 1
14,542,912,774 14,543,115,311 202,537 185,023 17,514 aten::_to_copy, op_id = 2 150,219 150,219 1 2 3 2 :2:3 --aten::_to_copy, op_id = 2
14,542,926,266 14,543,073,791 147,525 0 147,525 aten::empty_strided, op_id = 3 150,219 150,219 2 0 4 3 :2:3:4 ----aten::empty_strided, op_id = 3
14,543,077,036 14,543,114,534 37,498 0 37,498 aten::copy_, op_id = 4 150,219 150,219 2 0 5 3 :2:3:5 ----aten::copy_, op_id = 4
14,543,166,289 14,572,018,929 28,852,640 28,850,174 2,466 aten::to, op_id = 5 150,219 150,219 0 1 6 :6 aten::to, op_id = 5
14,543,167,747 14,572,017,921 28,850,174 28,839,916 10,258 aten::_to_copy, op_id = 6 150,219 150,219 1 2 7 6 :6:7 --aten::_to_copy, op_id = 6
14,543,171,058 14,543,440,984 269,926 0 269,926 aten::empty_strided, op_id = 7 150,219 150,219 2 0 8 7 :6:7:8 ----aten::empty_strided, op_id = 7
14,543,443,396 14,572,013,386 28,569,990 0 28,569,990 aten::copy_, op_id = 8 150,219 150,219 2 0 9 7 :6:7:9 ----aten::copy_, op_id = 8
14,572,058,541 14,572,061,218 2,677 0 2,677 aten::_has_compatible_shallow_copy_type, op_id = 9 150,219 150,219 0 0 10 :10 aten::_has_compatible_shallow_copy_type, op_id = 9
14,572,068,102 14,572,068,403 301 0 301 aten::_has_compatible_shallow_copy_type, op_id = 10 150,219 150,219 0 0 11 :11 aten::_has_compatible_shallow_copy_type, op_id = 10
Thanks, jkreibich for the insight. This solves the problem. For people who will visit in the future, I have enclosed a few entries of the result of the command suggested by jkreibich. We can see the nesting structure in NameTree field of the output. Each level of nesting is represented by two dashes. Thanks again for the help @hwilper @jkreibich
