NVTX range with Tensorflow
I’m using Tensorflow for inferencing and created a NVTX graph plugin that emits a start/end range per node in the graph. The problem is that since the NVTX calls are done on the host (nvtxRangeStartEx) the gpu optimizations there break.
Is there some way to emit a nvtxRangeStartEx from device code somehow?
thanks
Eyal
