Nvv412decoder drap_frame_interval
yes, the 40rtsp source are the same url
sorry, i think my fps is 1, because i seted the skip-frame=2
if skip-frame is set to 2, the decoder only decodes I frame. as you know, the I frame of 40 streams will arrive and be decoded at the different times. from the picture, the decoding usage is less than 30%, it is not too high.
I think I pulled 40 streams, all with skip settings_ Frame=2, the pressure on decoding is equivalent to pulling a camera with fps=40. Can I understand this way?
I think I pulled 40 streams, all with skip_frame=2, the pressure on decoding is equivalent to pulling a camera with fps=40. Can I understand this way?
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks.
the same point is that the decoder decodes 40 frame in one second. the different point is that decoding 40 I frames maybe is different with decoding one I Frame and 39 non-I frame. please refer to some decoding theory.
