Hello! I am trying to split the video obtained using nvv4l2camerasrc
element using nvtee
, one of the streams will be used for inference and the other transmitted using utp. However, when I execute the following pipeline, I get an error:
gst-launch-1.0 \
nvv4l2camerasrc \
device=/dev/video0 \
do-timestamp=1 \
bufapi-version=1 \
cap-buffers=16 \
! "video/x-raw(memory:NVMM), format=(string)UYVY, width=(int)1920, height=(int)1080, framerate=(fraction)30/1" \
! nvtee name=splitter0 \
! queue \
! fakesink \
splitter0.vid_src \
! queue \
! fakesink \
Error:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
0:00:06.438825977 4926 0x5579b61990 ERROR nvv4l2camerasrc gstnvv4l2camerasrc.cpp:475:gst_nvv4l2camera_buffer_pool_acquire_buffer:<nvv4l2camerabufferpool0> Timeout Error
Got EOS from element "pipeline0".
Execution ended after 0:00:06.354966121
Setting pipeline to READY ...
0:00:06.446233798 4926 0x5579b73290 ERROR nvv4l2camerasrc gstnvv4l2camerasrc.cpp:605:gst_nvv4l2camera_buffer_pool_release_buffer:<nvv4l2camerabufferpool0> VIDIOC_QBUF failed :Invalid argument
Setting pipeline to NULL ...
Freeing pipeline ...
(I actually removed the blocks to produce the minimum failing example.)
I am running on Jetson Nano.
$ cat /etc/nv_tegra_release
# R32 (release), REVISION: 7.3, GCID: 31982016, BOARD: t210ref, EABI: aarch64, DATE: Tue Nov 22 17:30:08 UTC 2022
$ uname -r
4.9.299-tegra
Jetpack 4.6.3 Deepstream 6.0
The camera used is:
Thank you in advance!
