Nvv4l2decoder bufapi-version property missing
• Hardware Platform Jetson
• DeepStream Version 5.0.1
• JetPack Version 4.5
• TensorRT 7.1.3.0
• Bug?
I recently updated to the new jetpack 4.5(l4t =32.5) from 4.4( l4t =32.4.4) and there seems to be a property missing for nvv4l2decoder, namely “bufapi-version”.
Setting it in code throws an error saying nvv4l2decoder does not have the “bufapi-version” property
This can also be verified by using gst-inspect-1.0 nvv4l2decoder, where “bufapi-version” is also missing?
Im not sure if ive missed something in the release notes but the python sample applications still try to set the property
regards Andrew
We will check this.
You may remove the “bufapi-version” property setting in deepstream_test_3.py and deepstream_imagedata-multistream.py.
I have noticed that the performance of the GstRtspServer is certainly worse with the new update (jetpack 4.5)
We are getting alot of ghosting and tearing artifacts while viewing the rtsp stream. This is happening with both the h264 and h265 encoders
below is the log from the client whislt trying to decode the stream
There should be no network issues as we are on the same gigabit network, via ethernet cables and only meters apart
[h264 @ 000002357cb8f540] negative number of zero coeffs at 43 52/302
[h264 @ 000002357cb8f540] error while decoding MB 43 52
[h264 @ 000002357cb8f540] concealing 1926 DC, 1926 AC, 1926 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet11
[rtsp @ 0000023574ede640] RTP: missed 2 packets
[rtsp @ 0000023574ede640] RTP: missed 8 packets
[rtsp @ 0000023574ede640] RTP: missed 6 packets
[h264 @ 000002357bde0580] negative number of zero coeffs at 87 55/314
[h264 @ 000002357bde0580] error while decoding MB 87 55
[h264 @ 000002357bde0580] concealing 1522 DC, 1522 AC, 1522 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet23
[rtsp @ 0000023574ede640] RTP: missed 69 packets
[h264 @ 000002357bc3b3c0] corrupted macroblock 81 48 (total_coeff=-1)
[h264 @ 000002357bc3b3c0] error while decoding MB 81 48
[h264 @ 000002357bc3b3c0] concealing 2368 DC, 2368 AC, 2368 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet36
[rtsp @ 0000023574ede640] RTP: missed 3 packets
[rtsp @ 0000023574ede640] RTP: missed 5 packets
[rtsp @ 0000023574ede640] RTP: missed 1 packets
[rtsp @ 0000023574ede640] RTP: missed 4 packets
[h264 @ 0000023574f7f8c0] corrupted macroblock 14 52 (total_coeff=16)
[h264 @ 0000023574f7f8c0] error while decoding MB 14 52
[h264 @ 0000023574f7f8c0] concealing 1955 DC, 1955 AC, 1955 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet49
[rtsp @ 0000023574ede640] RTP: missed 10 packets
[rtsp @ 0000023574ede640] RTP: missed 11 packets
[rtsp @ 0000023574ede640] RTP: missed 12 packets
[h264 @ 000002357c7b3700] out of range intra chroma pred mode=352/352
[h264 @ 000002357c7b3700] error while decoding MB 111 49
[h264 @ 000002357c7b3700] concealing 2218 DC, 2218 AC, 2218 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet63
[rtsp @ 0000023574ede640] RTP: missed 76 packets
[h264 @ 000002357bc3ad40] Invalid level prefix7KB sq=    0B f=366/366
[h264 @ 000002357bc3ad40] error while decoding MB 61 46
[h264 @ 000002357bc3ad40] concealing 2628 DC, 2628 AC, 2628 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet72
[rtsp @ 0000023574ede640] RTP: missed 33 packets
[h264 @ 000002357c740800] Invalid level prefix4KB sq=    0B f=373/373
[h264 @ 000002357c740800] error while decoding MB 22 55
[h264 @ 000002357c740800] concealing 1587 DC, 1587 AC, 1587 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet81
[h264 @ 0000023574f4ecc0] out of range intra chroma pred mode=385/385
[h264 @ 0000023574f4ecc0] error while decoding MB 85 54
[h264 @ 0000023574f4ecc0] concealing 1644 DC, 1644 AC, 1644 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet03
[h264 @ 000002357bc3ba40] out of range intra chroma pred mode=407/407
[h264 @ 000002357bc3ba40] error while decoding MB 21 53
[h264 @ 000002357bc3ba40] concealing 1828 DC, 1828 AC, 1828 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet17
[rtsp @ 0000023574ede640] RTP: missed 27 packets
[h264 @ 000002357cb8f540] out of range intra chroma pred mode=419/419
[h264 @ 000002357cb8f540] error while decoding MB 99 59
[h264 @ 000002357cb8f540] concealing 1030 DC, 1030 AC, 1030 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet29
[h264 @ 000002357bde0580] out of range intra chroma pred mode=433/433
[h264 @ 000002357bde0580] error while decoding MB 18 56
[h264 @ 000002357bde0580] concealing 1471 DC, 1471 AC, 1471 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet42
[rtsp @ 0000023574ede640] RTP: missed 7 packets
[h264 @ 000002357bc3b3c0] out of range intra chroma pred mode=444/444
[h264 @ 000002357bc3b3c0] error while decoding MB 96 54
[h264 @ 000002357bc3b3c0] concealing 1633 DC, 1633 AC, 1633 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet66
[rtsp @ 0000023574ede640] RTP: missed 25 packets
[rtsp @ 0000023574ede640] RTP: missed 32 packets
[rtsp @ 0000023574ede640] RTP: missed 19 packets
[h264 @ 000002357c7b3700] out of range intra chroma pred mode=467/467
[h264 @ 000002357c7b3700] error while decoding MB 21 46
[h264 @ 000002357c7b3700] concealing 2668 DC, 2668 AC, 2668 MV errors in I frame
[rtsp @ 0000023574ede640] RTP: missed 34 packets
[h264 @ 0000023574f9cac0] Invalid level prefix3KB sq=    0B f=475/475
[h264 @ 0000023574f9cac0] error while decoding MB 99 54
[h264 @ 0000023574f9cac0] concealing 1630 DC, 1630 AC, 1630 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet87
[rtsp @ 0000023574ede640] RTP: missed 77 packets
[h264 @ 000002357c740800] Invalid level prefix9KB sq=    0B f=488/488
[h264 @ 000002357c740800] error while decoding MB 116 46
[h264 @ 000002357c740800] concealing 2573 DC, 2573 AC, 2573 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet96
[rtsp @ 0000023574ede640] RTP: missed 16 packets
[h264 @ 0000023574f4ecc0] out of range intra chroma pred mode=499/499
[h264 @ 0000023574f4ecc0] error while decoding MB 108 47
[h264 @ 0000023574f4ecc0] concealing 2461 DC, 2461 AC, 2461 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet10
[h264 @ 0000023574f9c640] out of range intra chroma pred mode=511/511
[h264 @ 0000023574f9c640] error while decoding MB 65 53
[h264 @ 0000023574f9c640] concealing 1784 DC, 1784 AC, 1784 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet25
[rtsp @ 0000023574ede640] RTP: missed 14 packets
[h264 @ 000002357bc3ba40] out of range intra chroma pred mode=526/526
[h264 @ 000002357bc3ba40] error while decoding MB 9 57
[h264 @ 000002357bc3ba40] concealing 1360 DC, 1360 AC, 1360 MV errors in I frame
[h264 @ 000002357cb8f540] corrupted macroblock 96 57 (total_coeff=-1)
[h264 @ 000002357cb8f540] error while decoding MB 96 57
[h264 @ 000002357cb8f540] concealing 1273 DC, 1273 AC, 1273 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet46
[h264 @ 000002357bde0580] out of range intra chroma pred mode=549/549
[h264 @ 000002357bde0580] error while decoding MB 81 53
[h264 @ 000002357bde0580] concealing 1768 DC, 1768 AC, 1768 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet59
[h264 @ 000002357bc3b3c0] negative number of zero coeffs at 16 53/563
[h264 @ 000002357bc3b3c0] error while decoding MB 16 53
[h264 @ 000002357bc3b3c0] concealing 1833 DC, 1833 AC, 1833 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet74
[h264 @ 0000023574f7f8c0] corrupted macroblock 15 52 (total_coeff=16)
[h264 @ 0000023574f7f8c0] error while decoding MB 15 52
[h264 @ 0000023574f7f8c0] concealing 1954 DC, 1954 AC, 1954 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet92
[h264 @ 0000023574f9cac0] negative number of zero coeffs at 100 56594
[h264 @ 0000023574f9cac0] error while decoding MB 100 56
[h264 @ 0000023574f9cac0] concealing 1389 DC, 1389 AC, 1389 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet04
[rtsp @ 0000023574ede640] RTP: missed 9 packets
[rtsp @ 0000023574ede640] RTP: missed 20 packets
[h264 @ 000002357c740800] out of range intra chroma pred mode=606/606
[h264 @ 000002357c740800] error while decoding MB 15 52
[h264 @ 000002357c740800] concealing 1954 DC, 1954 AC, 1954 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet18
[h264 @ 0000023574f4ecc0] negative number of zero coeffs at 25 53/619
[h264 @ 0000023574f4ecc0] error while decoding MB 25 53
[h264 @ 0000023574f4ecc0] concealing 1824 DC, 1824 AC, 1824 MV errors in I frame
[h264 @ 0000023574f9c640] mb_type 114 in I slice too large at 34 5330
[h264 @ 0000023574f9c640] error while decoding MB 34 53
[h264 @ 0000023574f9c640] concealing 1815 DC, 1815 AC, 1815 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet40
[rtsp @ 0000023574ede640] RTP: missed 15 packets
[h264 @ 000002357bc3ba40] mb_type 405 in I slice too large at 29 5040
[h264 @ 000002357bc3ba40] error while decoding MB 29 50
[h264 @ 000002357bc3ba40] concealing 2180 DC, 2180 AC, 2180 MV errors in I frame
[h264 @ 000002357cb8f540] negative number of zero coeffs at 38 53/652
[h264 @ 000002357cb8f540] error while decoding MB 38 53
[h264 @ 000002357cb8f540] concealing 1811 DC, 1811 AC, 1811 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet62
[h264 @ 000002357bde0580] negative number of zero coeffs at 45 56/664
[h264 @ 000002357bde0580] error while decoding MB 45 56
[h264 @ 000002357bde0580] concealing 1444 DC, 1444 AC, 1444 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet73
[h264 @ 000002357bc3b3c0] out of range intra chroma pred mode=675/675
[h264 @ 000002357bc3b3c0] error while decoding MB 109 54
[h264 @ 000002357bc3b3c0] concealing 1620 DC, 1620 AC, 1620 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet00
[h264 @ 0000023574f9cac0] out of range intra chroma pred mode=702/702
[h264 @ 0000023574f9cac0] error while decoding MB 42 53
[h264 @ 0000023574f9cac0] concealing 1807 DC, 1807 AC, 1807 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet12
[rtsp @ 0000023574ede640] RTP: missed 80 packets
[h264 @ 000002357c740800] corrupted macroblock 117 45 (total_coeff=-1)
[h264 @ 000002357c740800] error while decoding MB 117 45
[h264 @ 000002357c740800] concealing 2692 DC, 2692 AC, 2692 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet27
[rtsp @ 0000023574ede640] RTP: missed 18 packets
[rtsp @ 0000023574ede640] RTP: missed 24 packets
[h264 @ 0000023574f4ecc0] negative number of zero coeffs at 33 46/727
[h264 @ 0000023574f4ecc0] error while decoding MB 33 46
[h264 @ 0000023574f4ecc0] concealing 2656 DC, 2656 AC, 2656 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet39
[h264 @ 0000023574f9c640] mb_type 34 in I slice too large at 54 53742
[h264 @ 0000023574f9c640] error while decoding MB 54 53
[h264 @ 0000023574f9c640] concealing 1795 DC, 1795 AC, 1795 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet52
[h264 @ 000002357bc3ba40] corrupted macroblock 24 51 (total_coeff=16)
[h264 @ 000002357bc3ba40] error while decoding MB 24 51
[h264 @ 000002357bc3ba40] concealing 2065 DC, 2065 AC, 2065 MV errors in I frame
[h264 @ 000002357cb8f540] corrupted macroblock 24 56 (total_coeff=16)
[h264 @ 000002357cb8f540] error while decoding MB 24 56
[h264 @ 000002357cb8f540] concealing 1465 DC, 1465 AC, 1465 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet77
[rtsp @ 0000023574ede640] RTP: missed 81 packets
[h264 @ 000002357bde0580] Invalid level prefix5KB sq=    0B f=780/780
[h264 @ 000002357bde0580] error while decoding MB 37 46
[h264 @ 000002357bde0580] concealing 2652 DC, 2652 AC, 2652 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet95
[h264 @ 000002357c742e80] corrupted macroblock 24 55 (total_coeff=-1)
[h264 @ 000002357c742e80] error while decoding MB 24 55
[h264 @ 000002357c742e80] concealing 1585 DC, 1585 AC, 1585 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet05
[h264 @ 000002357bdd49c0] out of range intra chroma pred mode=807/807
[h264 @ 000002357bdd49c0] error while decoding MB 119 47
[h264 @ 000002357bdd49c0] concealing 2450 DC, 2450 AC, 2450 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet28
[h264 @ 000002357c740800] mb_type 82 in I slice too large at 70 56
[h264 @ 000002357c740800] error while decoding MB 70 56
[h264 @ 000002357c740800] concealing 1419 DC, 1419 AC, 1419 MV errors in I frame
[h264 @ 0000023574f4ecc0] out of range intra chroma pred mode=843/843
[h264 @ 0000023574f4ecc0] error while decoding MB 82 47
[h264 @ 0000023574f4ecc0] concealing 2487 DC, 2487 AC, 2487 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet54
[h264 @ 0000023574f9c640] corrupted macroblock 28 46 (total_coeff=-1)
[h264 @ 0000023574f9c640] error while decoding MB 28 46
[h264 @ 0000023574f9c640] concealing 2661 DC, 2661 AC, 2661 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet78
[rtsp @ 0000023574ede640] max delay reached. need to consume packet79
[h264 @ 000002357cb8f540] negative number of zero coeffs at 30 51/882
[h264 @ 000002357cb8f540] error while decoding MB 30 51
[h264 @ 000002357cb8f540] concealing 2059 DC, 2059 AC, 2059 MV errors in I frame
[h264 @ 000002357c7b3700] Invalid level prefix8KB sq=    0B f=891/891
[h264 @ 000002357c7b3700] error while decoding MB 103 66
[h264 @ 000002357c7b3700] concealing 186 DC, 186 AC, 186 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet99
[h264 @ 000002357bc3ad40] out of range intra chroma pred mode=902/902
[h264 @ 000002357bc3ad40] error while decoding MB 33 55
[h264 @ 000002357bc3ad40] concealing 1576 DC, 1576 AC, 1576 MV errors in I frame
[h264 @ 000002357c742e80] out of range intra chroma pred mode=916/916
[h264 @ 000002357c742e80] error while decoding MB 12 52
[h264 @ 000002357c742e80] concealing 1957 DC, 1957 AC, 1957 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet26
[h264 @ 000002357bdd49c0] corrupted macroblock 24 46 (total_coeff=-1)
[h264 @ 000002357bdd49c0] error while decoding MB 24 46
[h264 @ 000002357bdd49c0] concealing 2665 DC, 2665 AC, 2665 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet37
[rtsp @ 0000023574ede640] max delay reached. need to consume packet38
[h264 @ 0000023574f9cac0] out of range intra chroma pred mode=941/941
[h264 @ 0000023574f9cac0] error while decoding MB 72 53
[h264 @ 0000023574f9cac0] concealing 1777 DC, 1777 AC, 1777 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet50
[h264 @ 000002357c740800] out of range intra chroma pred mode=953/953
[h264 @ 000002357c740800] error while decoding MB 99 54
[h264 @ 000002357c740800] concealing 1630 DC, 1630 AC, 1630 MV errors in I frame
[h264 @ 0000023574f4ecc0] corrupted macroblock 85 48 (total_coeff=16)
[h264 @ 0000023574f4ecc0] error while decoding MB 85 48
[h264 @ 0000023574f4ecc0] concealing 2364 DC, 2364 AC, 2364 MV errors in I frame
[h264 @ 0000023574f9c640] Invalid level prefix3KB sq=    0B f=979/979
[h264 @ 0000023574f9c640] error while decoding MB 7 46
[h264 @ 0000023574f9c640] concealing 2682 DC, 2682 AC, 2682 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet91
[h264 @ 000002357bc3ba40] left block unavailable for requested intra4x4 mode -1
[h264 @ 000002357bc3ba40] error while decoding MB 0 47
[h264 @ 000002357bc3ba40] concealing 2569 DC, 2569 AC, 2569 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1009
[rtsp @ 0000023574ede640] RTP: missed 47 packets
[h264 @ 000002357c7b3700] corrupted macroblock 101 53 (total_coeff=-1)9
[h264 @ 000002357c7b3700] error while decoding MB 101 53
[h264 @ 000002357c7b3700] concealing 1748 DC, 1748 AC, 1748 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1021
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1022
[h264 @ 000002357bc3ad40] negative number of zero coeffs at 35 584/1024
[h264 @ 000002357bc3ad40] error while decoding MB 35 58
[h264 @ 000002357bc3ad40] concealing 1214 DC, 1214 AC, 1214 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1035
[rtsp @ 0000023574ede640] RTP: missed 17 packets
[h264 @ 000002357c742e80] negative number of zero coeffs at 104 51/1035
[h264 @ 000002357c742e80] error while decoding MB 104 51
[h264 @ 000002357c742e80] concealing 1985 DC, 1985 AC, 1985 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1045
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1046
[h264 @ 000002357bdd49c0] corrupted macroblock 50 55 (total_coeff=-1)48
[h264 @ 000002357bdd49c0] error while decoding MB 50 55
[h264 @ 000002357bdd49c0] concealing 1559 DC, 1559 AC, 1559 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1059
[h264 @ 0000023574f9cac0] negative number of zero coeffs at 104 53/1061
[h264 @ 0000023574f9cac0] error while decoding MB 104 53
[h264 @ 0000023574f9cac0] concealing 1745 DC, 1745 AC, 1745 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1069
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1070
[h264 @ 000002357c740800] out of range intra chroma pred mode=1071/1071
[h264 @ 000002357c740800] error while decoding MB 36 50
[h264 @ 000002357c740800] concealing 2173 DC, 2173 AC, 2173 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1083
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1084
[h264 @ 0000023574f4ecc0] out of range intra chroma pred mode=1084/1084
[h264 @ 0000023574f4ecc0] error while decoding MB 68 58
[h264 @ 0000023574f4ecc0] concealing 1181 DC, 1181 AC, 1181 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1097
[h264 @ 0000023574f9c640] negative number of zero coeffs at 90 617/1097
[h264 @ 0000023574f9c640] error while decoding MB 90 61
[h264 @ 0000023574f9c640] concealing 799 DC, 799 AC, 799 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1120
[h264 @ 0000023574f7f8c0] corrupted macroblock 16 53 (total_coeff=16)
[h264 @ 0000023574f7f8c0] error while decoding MB 16 53
[h264 @ 0000023574f7f8c0] concealing 1833 DC, 1833 AC, 1833 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1134
[h264 @ 000002357c7b3700] out of range intra chroma pred mode=1135/1135
[h264 @ 000002357c7b3700] error while decoding MB 84 64
[h264 @ 000002357c7b3700] concealing 445 DC, 445 AC, 445 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1151
[h264 @ 000002357bc3ad40] mb_type 27 in I slice too large at 59 59/1152
[h264 @ 000002357bc3ad40] error while decoding MB 59 59
[h264 @ 000002357bc3ad40] concealing 1070 DC, 1070 AC, 1070 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1159
[rtsp @ 0000023574ede640] RTP: missed 23 packets
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1161
[h264 @ 000002357c742e80] corrupted macroblock 23 53 (total_coeff=16)61
[h264 @ 000002357c742e80] error while decoding MB 23 53
[h264 @ 000002357c742e80] concealing 1826 DC, 1826 AC, 1826 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1171
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1172
[h264 @ 000002357bdd49c0] out of range intra chroma pred mode=1173/1173
[h264 @ 000002357bdd49c0] error while decoding MB 26 57
[h264 @ 000002357bdd49c0] concealing 1343 DC, 1343 AC, 1343 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1182
[rtsp @ 0000023574ede640] RTP: missed 74 packets
[h264 @ 0000023574f9cac0] Invalid level prefix8KB sq=    0B f=1182/1182
[h264 @ 0000023574f9cac0] error while decoding MB 20 47
[h264 @ 0000023574f9cac0] concealing 2549 DC, 2549 AC, 2549 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1192
[h264 @ 000002357c740800] corrupted macroblock 111 52 (total_coeff=-1)4
[h264 @ 000002357c740800] error while decoding MB 111 52
[h264 @ 000002357c740800] concealing 1858 DC, 1858 AC, 1858 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1207
[rtsp @ 0000023574ede640] RTP: missed 36 packets
[h264 @ 0000023574f4ecc0] corrupted macroblock 33 54 (total_coeff=16)08
[h264 @ 0000023574f4ecc0] error while decoding MB 33 54
[h264 @ 0000023574f4ecc0] concealing 1696 DC, 1696 AC, 1696 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1226
[h264 @ 000002357bc3b3c0] corrupted macroblock 65 62 (total_coeff=-1)
[h264 @ 000002357bc3b3c0] error while decoding MB 65 62
[h264 @ 000002357bc3b3c0] concealing 704 DC, 704 AC, 704 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1249
[h264 @ 000002357c7b3700] dquant out of range (124) at 40 52f=1250/1250
[h264 @ 000002357c7b3700] error while decoding MB 40 52
[h264 @ 000002357c7b3700] concealing 1929 DC, 1929 AC, 1929 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1269
[h264 @ 000002357c742e80] mb_type 27 in I slice too large at 89 58/1275
[h264 @ 000002357c742e80] error while decoding MB 89 58
[h264 @ 000002357c742e80] concealing 1160 DC, 1160 AC, 1160 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1301
[h264 @ 0000023574f9cac0] corrupted macroblock 44 56 (total_coeff=16)02
[h264 @ 0000023574f9cac0] error while decoding MB 44 56
[h264 @ 0000023574f9cac0] concealing 1445 DC, 1445 AC, 1445 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1311
[rtsp @ 0000023574ede640] RTP: missed 78 packets
[h264 @ 000002357c740800] corrupted macroblock 13 46 (total_coeff=-1)15
[h264 @ 000002357c740800] error while decoding MB 13 46
[h264 @ 000002357c740800] concealing 2676 DC, 2676 AC, 2676 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1320
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1331
[h264 @ 000002357bde0580] corrupted macroblock 85 53 (total_coeff=16)
[h264 @ 000002357bde0580] error while decoding MB 85 53
[h264 @ 000002357bde0580] concealing 1764 DC, 1764 AC, 1764 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1334
[rtsp @ 0000023574ede640] RTP: missed 1905 packets
[h264 @ 000002357c742e80] cbp too large (3199971767) at 118 62
[h264 @ 000002357c742e80] error while decoding MB 118 62
[h264 @ 000002357c742e80] concealing 651 DC, 651 AC, 651 MV errors in P frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1342
[h264 @ 0000023574f9c640] negative number of zero coeffs at 26 542/1342
[h264 @ 0000023574f9c640] error while decoding MB 26 54
[h264 @ 0000023574f9c640] concealing 1703 DC, 1703 AC, 1703 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1353
[h264 @ 000002357bc3ba40] Invalid level prefix3KB sq=    0B f=1355/1355
[h264 @ 000002357bc3ba40] error while decoding MB 82 67
[h264 @ 000002357bc3ba40] concealing 87 DC, 87 AC, 87 MV errors in I frame
[rtsp @ 0000023574ede640] max delay reached. need to consume packet1362
[h264 @ 000002357cb8f540] Invalid level prefix4KB sq=    0B f=1364/1364
[h264 @ 000002357cb8f540] error while decoding MB 118 45
[h264 @ 000002357cb8f540] concealing 2691 DC, 2691 AC, 2691 MV errors in I frame
 218.88 M-V:  0.006 fd=1315 aq=    0KB vq=  289KB sq=    0B f=1368/1368
are the some parameters we need to tune? I have tried adjusting the bitrate and it has no effect
Regards Andrew
@Fiona.Chen
I can make a new topic but I’m not sure if maybe these two things could be related?
I can also confirm that I have two agx’s 1 on jetpack 4.4 and the other on 4.5, the video stream is far more “decodeable” and has minimal artifacts and less errors from ffmpeg. whilst the stream the 4.5 agx is really bad and has large amounts of error messages as shown above
I upgraded to jetpack 4.5.1 and the problem still persists, deepstream 5.0.1
New topic Rtsp Server artifacts with jetpack 4.5 - Intelligent Video Analytics / DeepStream SDK - NVIDIA Developer Forums has been created for the rtsp issue. Close this topic.
