RTX 2060
• DeepStream Version
Deepstream 6.0
• TensorRT Version
TensorRT 8.0
470
I try to use this command:
gst-launch-1.0 rtspsrc location=rtsp://localhost:8554/001 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw,format=RGBA ! videoconvert ! video/x-raw,format=BGR
! fakesink
and got this error:
gst-launch-1.0 rtspsrc location=rtsp://localhost:8554/001 ! rtph264depay ! h264parse ! nvv4l2decoder ! nvvideoconvert ! video/x-raw,format=RGBA ! videoconvert ! video/x-raw,format=BGR ! fakesink
设置暂停管道 ...
管道正在使用且不需要 PREROLL ...
进度:(open)Opening Stream
进度:(connect)Connecting to rtsp://localhost:8554/001
进度:(open)Retrieving server options
进度:(open)Retrieving media info
进度:(request)SETUP stream 0
进度:(request)SETUP stream 1
进度:(open)Opened Stream
设置播放管道 ...
New clock: GstSystemClock
进度:(request)Sending PLAY request
进度:(request)Sent PLAY request
错误:来自组件 /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0:Device '/dev/nvidia0' failed during initialization
额外的调试信息:
gstv4l2object.c(4116): gst_v4l2_object_set_format_full (): /GstPipeline:pipeline0/nvv4l2decoder:nvv4l2decoder0:
Call to S_FMT failed for H264 @ 0x0: 未知的错误 -1
Execution ended after 0:00:02.107735593
设置暂停管道 ...
设置备用管道 ...
设置 NULL 管道 ...
释放管道资源 ...
use gst_debug ,got detail info:
0:00:04.094753434 3744 0x7f92f40288c0 WARN default v4l2-utils.c:189:gst_v4l2_error:<nvv4l2decoder0> error: Device '/dev/nvidia0' failed during initialization
0:00:04.094806245 3744 0x7f92f40288c0 WARN default v4l2-utils.c:192:gst_v4l2_error:<nvv4l2decoder0> error: Call to S_FMT failed for H264 @ 0x0: 未知的错误 -1
0:00:04.094877495 3744 0x7f92f40288c0 WARN videodecoder gstvideodecoder.c:743:gst_video_decoder_setcaps:<nvv4l2decoder0> Subclass refused caps
额外的调试信息:
Execution ended after 0:00:02.016260980
设置暂停管道 ...
0:00:04.095405014 3744 0x7f92f40288c0 WARN default v4l2-utils.c:189:gst_v4l2_error:<nvv4l2decoder0> error: Device '/dev/nvidia0' failed during initialization
0:00:04.095435331 3744 0x7f92f40288c0 WARN default v4l2-utils.c:192:gst_v4l2_error:<nvv4l2decoder0> error: Call to S_FMT failed for H264 @ 0x0: 未知的错误 -1
设置备用管道 ...
0:00:04.095474295 3744 0x7f92f40288c0 WARN videodecoder gstvideodecoder.c:743:gst_video_decoder_setcaps:<nvv4l2decoder0> Subclass refused caps
0:00:04.095493847 3744 0x7f92f40288c0 WARN GST_PADS gstpad.c:4231:gst_pad_peer_query:h264parse0:src could not send sticky events
0:00:04.096030127 3744 0x56401169a0c0 WARN rtspsrc gstrtspsrc.c:6322:gst_rtsp_src_receive_response:<rtspsrc0> receive interrupted
0:00:04.096067375 3744 0x56401169a0c0 WARN rtspsrc gstrtspsrc.c:8650:gst_rtspsrc_pause:<rtspsrc0> PAUSE interrupted
设置 NULL 管道 ...
释放管道资源 ...
Call to S_FMT failed for H264 @ 0x0 unknown error! Device ‘/dev/nvidia0’ failed during initialization error, why?
