Nvv4l2decoder has no property named enable-max-performance
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 5.1
• TensorRT Version: 7.2.3
• NVIDIA GPU Driver Version (valid for GPU only): 460.73.01
• Issue Type( questions, new requirements, bugs): questions
When I set enable-max-performance for nvv4l2decoder:
decoder = gst_element_factory_make("nvv4l2decoder", element_name);
g_object_set (G_OBJECT (decoder), "enable-max-performance", 1, NULL);
I get:
 GLib-GObject-WARNING **: 13:48:28.138: g_object_set_is_valid_property: object class 'nvv4l2decoder' has no property named 'enable-max-performance'
Is enable-max-performance property for nvv4l2decoder depreacated in deepstream 5.1? Is there any new property for the max-performance? Or the max-performance is set by default?
Thank you
What is your GPU type?
Sorry, it is rtx 3090
“enable-max-performance” property is only for Jetson platform. Embedded Systems Developer Kits & Modules from NVIDIA Jetson
