Nvv4l2decoder has no property named rtsp-reconnect-interval-sec
• Tx2
• 4.0.2
• JetPack 4.3
• TensorRT 6.0
in my application, the rtsp camera often drop to 0, so I merge rtsp-reconnect-interval-sec to deepstream 4.0.2, but some device , it report no the property.
can you tell me what need to install. thank you.
the log:
(deepstream-app:26983): GLib-GObject-WARNING **: 10:18:27.549: g_object_set_is_valid_property: object class ‘nvv4l2decoder’ has no property named ‘rtsp-reconnect-interval-sec’
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteOpen : Block : BlockType = 261
NvMMLiteBlockCreate : Block : BlockType = 261
(deepstream-app:26983): GLib-GObject-WARNING **: 10:18:27.612: g_object_set_is_valid_property: object class ‘nvv4l2decoder’ has no property named ‘rtsp-reconnect-interval-sec’
Even in DeepStream 5.0 , ‘rtsp-reconnect-interval-sec’ is not nvv4l2decoder property. So you need to check and debug with you codes to find out where and when it is set as nvv4l2decoder property.
it is my code error, now it is ok。
