Hello!
We’ve been making use of GStreamer & webrtcbin on Jetson and desktop Nvidia setups for a few years now, and everything has worked very well.
In the past we found that, when using our pipeline on Jetson, we needed to use the omxh264enc
encoder as nvv4l2h264enc
had too many bugs in it that clashed with webrtcbin. Recently we finally made the switch to Jetpack 5.0.2 which of course no longer supports the omx encoder.
The problem: When using webrtcbin
with nvv4l2h264enc
(& nvvidconv
) we run into some consistent delays (by as much as 30 seconds!) in the start of the WebRTC streams.
Observations:
- Switching to
openh264enc
fixes the issue. - Also, using the same code (and same version of GStreamer) on a desktop machine with
nvh264enc
also works perfectly well. - We are using GStreamer 1.21.1 as we have found it has the fewest issues, but we have also tried with the latest stable versions.
Has anyone else encountered this? Any ideas?
