I want to use deepstream and I need to be able to use plugins like nvstreammux. I have been using nvvideoconvert in my pipeline, however it turns grayscale images a geenish/yellow color. It is a truly revolting color. To illustrate this the following method works perfectly:
This method works:
gst-launch-1.0 aravissrc ! ‘video/x-raw, width=(int)2048, height=(int)1536, framerate=30/1, format=(string)GRAY8’ ! nvvidconv ! nvegltransform ! nveglglessink sync=false
This method DOES NOT work - results in a greenish/yellow image:
gst-launch-1.0 aravissrc ! ‘video/x-raw, width=(int)2048, height=(int)1536, framerate=30/1, format=(string)GRAY8’ ! nvvideoconvert ! nvegltransform ! nveglglessink sync=false
I have Googled around with no luck, any help would be greatly appreciated.
Thanks,
