Nvvideoconvert to RGBA fails with nvdsanaytics plugin
Jetson Xavier NX
• DeepStream Version
5.0
4.4
• TensorRT Version
bugs
Explained in detail below
I am trying to combine the two example notebooks : image_metadata and nvdsanalytics.
I started with the nvdsanalytics script; I added the piece of code following after the pgie element and before the tracker element:
nvvidconv_postinfer = Gst.ElementFactory.make("nvvideoconvert", "convertor_postinfer-%u"%i)
if not nvvidconv_postinfer:
       sys.stderr.write(" Unable to create nvvidconv_postinfer \n")
pipeline.add(nvvidconv_postinfer)
pgie.link(nvvidconv_postinfer)
caps_postinfer = Gst.ElementFactory.make("capsfilter", "post_infer_filter-%u"%i)
caps_postinfer.set_property("caps", Gst.Caps.from_string("video/x-raw(memory:NVMM),format=RGBA"))
pipeline.add(caps_postinfer)
nvvidconv_postinfer.link(caps_postinfer)
caps_postinfer.link(tracker)
Just adding the above snippet cause the pipeline to build successfully but fails during playing with : Segmentation Fault(core dumped)
Please upgrade to latest deepstream 6.0.
@Fiona.Chen thanks for getting back quickly. Is this definetly a version issue. Im just asking because I have to redo my whole setup.
I have tried with DS 6.0 GA version, I can not reproduce the problem.
hey @Fiona.Chen the issue got solved using Deepstream 6.0. Thanks a lot.
