Hi all,
we have a problem when using nvvideosink. The pipeline is running, but we are flooded with “Wrong surface count in ConvertBuffer”.
This is our code:
// Build pipeline
m_pPipeline = gst_pipeline_new("pipeline");
m_testSource = gst_element_factory_make("videotestsrc", "testsrc");
GstElement* vc = gst_element_factory_make("videoconvert", "vc");
m_testSourceFilter = gst_element_factory_make("capsfilter", "testsrc_filter");
m_nvVideoConv = gst_element_factory_make("nvvideoconvert", "vidconv");
m_nvVideoConvFilter = gst_element_factory_make("capsfilter", "vidconv_filter");
m_sink = gst_element_factory_make("nvvideosink", "nvvideosink");
// add elements to pipeline
gst_bin_add_many( GST_BIN (m_pPipeline),
m_testSource,
vc,
m_testSourceFilter,
m_nvVideoConv,
m_nvVideoConvFilter,
m_sink,
NULL);
g_object_set( G_OBJECT(m_sink),
"display", _display,
"stream", _eglstream,
"sync", false,
"async", false,
NULL);
// Set caps.
m_testSourceFilterCaps = gst_caps_from_string("video/x-raw, width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)I420");
g_object_set(G_OBJECT(m_testSourceFilter), "caps", m_testSourceFilterCaps, NULL);
m_nvVideoConvFilterCaps = gst_caps_from_string("video/x-raw(memory:NVMM), width=(int)1280, height=(int)720, framerate=(fraction)60/1, format=(string)I420");
g_object_set(G_OBJECT(m_nvVideoConvFilter), "caps", m_nvVideoConvFilterCaps, NULL);
// Linking.
if (!gst_element_link_many( m_testSource,
vc,
m_testSourceFilter,
m_nvVideoConv,
m_sink,
nullptr))
qInfo("Not all GstElements could be linked!");
Notes:
- we added the 'normal' videoconvert to the pipeline without success. The result without it is the same
- We can assure that the display and stream is valid as another pipeline (h264 decode from an appsrc) is running fine
- When using "nvoverlaysink" instead - the stream is renderered properly
Did anyone encounter a similar problem and has some insights?
Is the code for “nvvideosink” available, so we could have a look into what is throwing this message?
Thanks + Best regards,
Bodo
