Hello.
My code compiles in release mode, but not in debug mode.
Following is the error message.
nvvmCompileProgram error: 9.
Error: C:\Users\USER\AppData\Local\Temp\pgacc2awaPdcSMtgeu7.gpu (195, 146): parse use of undefined metadata ‘!8895134’
pgnvd-Fatal-Could not spawn C:\Program Files\PGI\win64\15.10\bin\pgnvvm.exe
And following is the code section where problem occurs.
#include <CUDADEFINES.h>
MODULE CUDACONST
IMPLICIT NONE
INTEGER, CONSTANT :: nfsr, nxy, nz, nzf, ng, nofg, norg, nchi
INTEGER, CONSTANT :: nRotRay, nModRay, nAziAngle, nPolarAngle, nPhiAngSv, nMoment, ScatOd
INTEGER, CONSTANT :: InScatRange(2, GPU_MAX_GROUP), AziMap(GPU_MAX_AZI, 2), dir(2, 2), inc(2)
REAL(GPU_PRECISION), CONSTANT :: rsinv(GPU_MAX_POLAR), sinv(GPU_MAX_POLAR)
REAL(GPU_PRECISION), CONSTANT :: wt(GPU_MAX_POLAR, GPU_MAX_AZI), wt1D(GPU_MAX_POLAR)
REAL(GPU_PRECISION), CONSTANT :: wtsurf(4, GPU_MAX_POLAR, GPU_MAX_AZI), wtsurf1D(GPU_MAX_POLAR)
REAL(GPU_PRECISION), CONSTANT :: Comp(GPU_MAX_ORDER, GPU_MAX_POLAR, GPU_MAX_AZI)
REAL(GPU_PRECISION), CONSTANT :: mwt(GPU_MAX_ORDER, GPU_MAX_POLAR, GPU_MAX_AZI)
END MODULE
MODULE CUDAMOD
USE CUDATypeDef, ONLY : cuMOC_Type, cuCMFD_Type, cuDevice_Type, cuWorkset_Type, &
cuRotRay_Type, cuDcmpRay_Type, cuXsData_Type, cuFxr_Type, &
cuIsotope_Type, cuAxial_Type
USE CUDAFOR
USE CUSPARSE
USE CUBLAS
IMPLICIT NONE
TYPE(cuMOC_Type), POINTER :: cuMOC(:)
TYPE(cuCMFD_Type), POINTER :: cuCMFD(:)
TYPE(cuDevice_Type), POINTER :: cuDevice(:)
TYPE(cuWorkset_Type), POINTER :: hostWorkset(:, :)
TYPE(cudaEvent) :: startEvent, stopEvent
TYPE(cusparseHandle), POINTER :: sparseHandle(:)
TYPE(cublasHandle), POINTER :: blasHandle(:)
INTEGER(KIND = cuda_stream_kind), POINTER :: cuStream(:)
TYPE(cuRotRay_Type), POINTER :: cuFastRay(:, :), cuCellRay(:)
TYPE(cuDcmpRay_Type), POINTER :: cuDcmpRay(:)
TYPE(cuFxr_Type), POINTER :: cuFxr(:)
TYPE(cuIsotope_Type), POINTER :: cuIsotope(:, :)
TYPE(cuXsData_Type), POINTER :: cuXsData(:)
TYPE(cuAxial_Type), POINTER :: cuAxial(:)
INTEGER, ALLOCATABLE :: AxType(:), AxTypeGroup(:, :), AxTypeInterface(:, :)
INTEGER :: nAxType, nInterface
!--- CUDA Unified Memory for Domain Connected Pn Ray Tracing
REAL(GPU_PRECISION), ALLOCATABLE, MANAGED :: __phim(:, :, :)
REAL :: loadFactor(2, 2, 2), executionTime(2, 2, 2)
INTEGER(8) :: totalWorkload
INTERFACE
SUBROUTINE BaseCellRaySort(Core, RayInfo, BCRSort)
USE PARAM
USE TYPEDEF, ONLY : CoreInfo_Type, RayInfo_Type
USE CUDATypeDef, ONLY : cuBCR_Type
IMPLICIT NONE
TYPE(CoreInfo_Type) :: Core
TYPE(RayInfo_Type) :: RayInfo
TYPE(cuBCR_Type), POINTER :: BCRSort(:)
END SUBROUTINE
SUBROUTINE AssignGPUPlane(cuDevice)
USE PARAM
USE CUDATypeDef, ONLY : cuDevice_Type
IMPLICIT NONE
END SUBROUTINE
SUBROUTINE SetControlVar(Core, RayInfo, cuDevice)
USE PARAM
IMPLICIT NONE
END SUBROUTINE
SUBROUTINE CopyRayVar(Core, RayInfo, BCRSort, cuDevice)
USE PARAM
USE CUDATypeDef, ONLY : cuBCR_Type, cuDevice_Type
IMPLICIT NONE
TYPE(cuDevice_Type) :: cuDevice
END SUBROUTINE
SUBROUTINE CUDALoadRebalance(RayInfo, InIter, iSweep, loadFactor, executionTime)
USE PARAM
USE TYPEDEF, ONLY : RayInfo_Type
IMPLICIT NONE
INTEGER :: InIter, iSweep
REAL, OPTIONAL :: executionTime(2, 2, 2)
END SUBROUTINE
END INTERFACE
END MODULE
Having two modules in one source file is problematic?
