Nvvrs-pseq-rtc (rtc0) resets to epoch on every boot despite confirmed-good RTC backup battery — AGX Thor Developer Kit
Platform:
  • NVIDIA Jetson AGX Thor Developer Kit
  • L4T R38.4.0 (GCID 43443517, kernel 6.8.12-tegra)
  • RTC battery: 3V CR2032, keyed 2-pin JST connector, plugged into the carrier board’s labeled “RTC BATT” header
Issue:
rtc0 (nvvrs-pseq-rtc, the PMIC/power-sequencer RTC that the system actually uses for timekeeping — confirmed via /dev/rtc -> rtc0 and timedatectl) resets to 1970-01-01T00:00:30 UTC on every single power cycle, regardless of RTC backup battery state. rtc1 (tegra_rtc) is not battery-backed and resets as expected — that’s not in question here.
Evidence gathered (all reproducible, logged via sudo dmesg | grep -i "setting system clock"):
Test Battery state Connector rtc0 boot-time read
1 Original battery, connected Keyed, correctly seated 1970-01-01T00:00:30 UTC
2 Fresh replacement battery, connected Keyed, correctly seated 1970-01-01T00:00:30 UTC (identical)
3 Battery physically disconnected N/A 1970-01-01T00:00:30 UTC (identical)
4 Battery reconnected Keyed, correctly seated 1970-01-01T00:00:30 UTC (identical)
Hardware verified good:
  • Measured 3.04V DC directly across the two connector pins, with the Jetson fully powered off (main power removed) — confirms the battery is delivering correct voltage to the connector during exactly the window the backup domain needs it.
  • Connector is physically keyed, so reversed polarity is not possible.
  • No I2C/driver errors anywhere in dmesg/journalctl — hwclock -r/-w against /dev/rtc0 complete cleanly every time, no bus timeouts, no “Cannot access Hardware Clock” errors.
Possibly related: nvvrs_pseq 5-003c occasionally logs CAUTION: interrupt status reg:0x10 set to 0x8 near boot. This did not correlate reliably with battery connected/disconnected state across repeated tests, so it may be unrelated — but if NVIDIA has the register map for this bit, confirmation either way would help rule it in or out.
Also worth noting for anyone else hitting this: systemd-timesyncd’s own saved-clock restore (System clock time unset or jumped backwards, restored from recorded timestamp...) kicks in immediately at boot, well before NTP actually contacts a server (8+ minutes later in our case). This makes the system clock look correct almost immediately after boot even though the underlying RTC hardware read failed — easy to mistake for the battery “working” when it isn’t.
In general my question is, how do i get the RTC Battery to work with the Jetson Thor so that i can correctly keep track of time even when there is not network connection.
The rtc batteries I am using are: NVIDIA Jetson AGX ORIN RTC Battery | MYBOTSHOP.DE, € 12,90
