I want to adapt the number of keypoints extracted at runtime with nvxFastTrackNode
(VisionWorks 1.6.0.501). For that, I’m trying to change the value of the threshold parameter between graph executions, based on the number of extracted keypoints at the previous execution.
I’m calling the following in between graph executions
fast_thresh_ = getUpdatedThreshold();
vxSetParameterByIndex(fast_node_, 7, vx_reference(&fast_thresh_))
vxProcessGraph(track_graph_);
but at runtime I get:
vxSetParameterByIndex: invalid value reference
Alternatively, in the documentation, it states that:
node parameter objects may be modified by retrieving the reference to the
vx_parameter
viavxGetParameterByIndex
, and then passing that tovxQueryParameter
to retrieve the reference to the object.
with :
vx_parameter param = vxGetParameterByIndex(node_, 7);
vx_reference ref;
vxQueryParameter(param, VX_PARAMETER_REF, &ref, sizeof(ref));
But then how do I change the value pointed by the reference ?
Thanks for your help.
