HI Team,
we are using Xavier NX with kernel 4.9 and R32.4.3 release.
In it we added device tree entry and camera(ar0821) camera sensor driver. And we also able to get video node(video0).
But when we are running v4l2-ctl command :
v4l2-ctl --set-fmt-video=width=3840,height=2160,pixelformat=RAW12 --set-ctrl bypass_mode=0 --stream-mmap --stream-count=1 --stream-to=ar0821.raw -d /dev/video0
then
we are getting following log :
tegra194-vi5 15c10000.vi: corr_err: discarding frame 0, flags: 160, err_data 1188
and when we checked debug/tracing logs then it show :
kworker/0:3-1687 [000] .... 156.115694: rtcpu_vinotify_event: tstamp:5202577339 tag:CHANSEL_NOMATCH channel:0x90 frame:33152 vi_tstamp:5202394476 data:0x04000409
kworker/0:3-1687 [000] .... 156.339987: rtcpu_vinotify_error: tstamp:5209827178 tag:CHANSEL_NOMATCH channel:0x10 frame:16513 vi_tstamp:5208866234 data:0x00000509
kworker/0:3-1687 [000] .... 156.340010: rtcpu_vinotify_event: tstamp:5209828502 tag:CHANSEL_SHORT_FRAME channel:0x10 frame:20 vi_tstamp:5208863542 data:0x01000000
kworker/0:3-1687 [000] .... 156.340036: rtcpu_vinotify_event: tstamp:5209829241 tag:CHANSEL_NOMATCH channel:0x10 frame:16513 vi_tstamp:5208866234 data:0x00000509
kworker/0:3-1687 [000] .... 156.340106: rtcpu_vinotify_event: tstamp:5210037247 tag:CHANSEL_FAULT_FE channel:0x10 frame:16513 vi_tstamp:5209894743 data:0x00000000
Full logs are attached.
trace_logs_cam (16.7 MB)
trace_logs_cam_dmesg (3.4 KB)
Alks
