I have created a custom mode in the NX enabling all 6 cores at 1.9GHz max.
I don’t intend to use much GPU and so far the power consumed (while stress all 6core didn’t go up 11W) doesn’t seem to reach the limit of 15W, what I would like to know is if I could use this mode reliably or did you did any test that you don’t recommend to use this mode.
please refer to Supported Modes and Power Efficiency.
you should note that it’ll only enable 2-CPUs for the maximum performance mode, (i.e. mode-0.)
thanks
Yes I have followed this page to define a custom power mode and after setting it I check the tegrastats and all 6cores are clearly at 1.9GHz.
I would like to know if you did any test in this mode to know if I could use it reliably.
the CPU operation of Xavier NX did mention six cores running at 1.9GHz for 15W power mode.
please also check Xavier NX Module Data Sheet. you may refer to Chapter-1.2 Carmel CPU Complex for more details.
thanks
Thank you for the answer
In the document you shared it again only mentions the 1.4GHz for the 6 cores and the 1.9GHz for only 2 cores that is why I was worried to set and use at 1.9GHZ on all 6 cores.
If that is not the case and I can set a custom mode with all 6 cores at 1.9GHz for the 15W power mode I will assume is reliable to use.
Thank you for your help and time
