Hello @gtj,
I have managed to use update-initramfs
generated initrd
on Xavier AGX by adding hook to copy xusb firmware: AGX thread . It works with root=PARTUUID=XXXXXXXX-XXXX-XXXX-XXXX->XXXXXXXXXXXX
and for unknown reason doesn’t work with root=/dev/nvme0n1p1
. I haven’t tried with root=UUID=actual_uuid
APPEND yet.
As for stock initrd
from JetPack 4.4 DP, it has very strange commandline parsing in init
script ( at AGX thread ):
There is this script (remove .log): init.log (5.7 KB)
62: rootdev="$(sed -ne 's/.*\broot=\/dev\/\([abcdefklmnps0-9]*\)\b.*/\1/p' < /proc/cmdline)"
63: if [ "${rootdev}" == "" ]; then
64: uuid_regex='[0-9a-f]\{8\}-[0-9a-f]\{4\}-[0-9a-f]\{4\}-[0-9a-f]\{4\}-[0-9a-f]\{12\}'
65: rootdev="$(sed -ne "s/.*\broot=\(PARTUUID=${uuid_regex}\)\b.*/\1/p" < /proc/cmdline)"
66:fi
First it search for rootdevice by name “/dev/*” and if it isn’t found, for one set by PARTUUID
On devices flashed by JetPack first root=/dev/mmcblk0p1
is prepended by cboot to command line, so rootdevice set by
APPEND ${cbootargs} root=PARTUUID=XXXXXXXX-XXXX-XXXX-XXXX->XXXXXXXXXXXX quiet
will be completely ignored. On line 62 rootdev
will be set to “mmcblk0p1” from first “root=…” parameter and lines 64-65 will be skipped.
form is not parsed at all.
So, to change rootfs with APPEND in extlinux.conf now we need to patch init
script in stock initrd
or generate new initrd
Or use systemd service method: https://github.com/jetsonhacks/rootOnNVMe
