I have followed e-conn systems guide on how to apply their dtb to the kernal and have gotten their cameras working on the AGX.
and then reflashed my AGX. Now the e-conn cameras do not work.
I did a little digging and see that the ./flash command uses a different board name, which in turn makes the DTB_FILE variable change between the e-conn systems one and the NX Emulation one.
What are the proper steps to take here? E-conn systems docs have a step by step process for building from source, however I do not see the same for the NX emulation changes, and am unsure how I can combine the NX emulation with the e-conn systems setup.
Please advise, TIA.
- Ian
