We have requirement to encode 3 video streams of size 1472x540 via gstreamer.
System details:
** R32.4.3**
** Kernel version 4.9.140-tegra**
We use c program to perform the operation
Pipeline looks as follows
gst_parse_launch_full: parsing pipeline description 'appsrc name=appsrc_cam0_full ! rawvideoparse use-sink-caps=false width=1472 height=540 format=gray16-le ! videoconvert ! video/x-raw,format=I420 ! timeoverlay ! omxh265enc ! h265parse ! queue ! matroskamux ! filesink location=trt_xtend_00.mkv sync=false async=false appsrc name=appsrc_cam1_full ! rawvideoparse use-sink-caps=false width=1472 height=540 format=gray16-le ! videoconvert ! video/x-raw,format=I420 ! timeoverlay ! omxh265enc ! h265parse ! queue ! matroskamux ! filesink location=trt_xtend_01.mkv sync=false async=false appsrc name=appsrc_cam2_full ! rawvideoparse use-sink-caps=false width=1472 height=540 format=gray16-le ! videoconvert ! video/x-raw,format=I420 ! timeoverlay ! omxh265enc ! h265parse ! queue ! matroskamux ! filesink location=trt_xtend_02.mkv sync=false async=false
After continuosly running 140 odd shots, C application crashes with the following errors. Please find the extented log here encode-crash-gstreamer.txt (1.5 MB)
NvMMLiteVideoEncDoWork:NvMSEncConvertSurfaceFormat failed
VENC: NvMMLiteVideoEncDoWork: 4283: BlockSide error 0x4
Event_BlockError from 459BlockHevcEnc : Error code - 4
Sending error event from 459BlockHevcEnc0:29:07.104717364 20114 0x7f00eacc40 ERROR omx gstomx.c:496:EventHandler: encoder got error: Bad parameter (0x80001005)
0:29:07.104820790 20114 0x7ee0401630 ERROR omx gstomx.c:268:gst_omx_component_handle_messages: encoder got error: Bad parameter (0x80001005)
0:29:07.104858998 20114 0x7ee0401630 ERROR omx gstomx.c:1285:gst_omx_port_acquire_buffer: Component encoder is in error state: Bad parameter
0:29:07.104883351 20114 0x7ee0401630 WARN omxvideoenc gstomxvideoenc.c:1331:gst_omx_video_enc_loop: error: OpenMAX component in error state Bad parameter (0x80001005)
0:29:07.104932887 20114 0x7ee0401630 INFO GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details: posting message: GStreamer encountered a general supporting library error.
0:29:07.105194267 20114 0x7ee0401630 INFO GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details: posted error message: GStreamer encountered a general supporting library error.
0:29:07.105496543 20114 0x7ee0401630 INFO task gsttask.c:316:gst_task_func:omxh265enc-omxh265enc460:src Task going to paused
0:29:07.105625601 20114 0x7f102108f0 INFO ebmlwrite ebml-write.c:523:gst_ebml_write_seek: scheduling seek to 527
0:29:07.105650625 20114 0x7f102108f0 INFO ebmlwrite ebml-write.c:216:gst_ebml_writer_send_segment_event: seeking to 527
0:29:07.105705826 20114 0x7f102108f0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event bytes segment start=527, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1
0:29:07.105987750 20114 0x7f102108f0 INFO ebmlwrite ebml-write.c:523:gst_ebml_write_seek: scheduling seek to 3865
0:29:07.106070535 20114 0x7f102108f0 INFO ebmlwrite ebml-write.c:216:gst_ebml_writer_send_segment_event: seeking to 3865
0:29:07.106111528 20114 0x7f102108f0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event bytes segment start=3865, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1** (turtle_sa:20114): ERROR **: 17:12:08.886: received error
0:29:07.106213961 20114 0x7f102108f0 INFO ebmlwrite ebml-write.c:523:gst_ebml_write_seek: scheduling seek to 76
0:29:07.106304107 20114 0x7f102108f0 INFO ebmlwrite ebml-write.c:216:gst_ebml_writer_send_segment_event: seeking to 76
0:29:07.106351403 20114 0x7f102108f0 INFO GST_EVENT gstevent.c:895:gst_event_new_segment: creating segment event bytes segment start=76, offset=0, stop=-1, rate=1.000000, applied_rate=1.000000, flags=0x00, time=0, base=0, position 0, duration -1
Trace/breakpoint trap (core dumped)
I had tried using nvv4l2h265enc and still leading to crash.
Kindly provide support to fix the issue.
