Hello, I need to dynamically add and reduce video sources. In 2060, there is no problem, but in NX, only the first video can be run, and the second one will never trigger “pad added”
Hello, this is an example I wrote. Please help me analyze it. It has not been solved for a week. There is no problem on 2060 and 3090. The video can be played normally. You can only play one video on nx.
yes,Deepstream6.1.1,After the first video connection is successful, there is no feedback from the last two videos. The same is true for the example of “runtime_source_add_delete”
max_fps_dur 8.33333e+06 min_fps_dur 2e+08
Creating H264 Encoder
Creating H264 rtppay
Opening in BLOCKING MODE
add video source rtsp://localhost:8555/live/101 0
STATE CHANGE NO PREROLL
Error: gst-resource-error-quark: Could not get/set settings from/on resource. (13): gstmultiudpsink.c(1285): gst_multiudpsink_configure_client (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin-0/GstRTSPSrc:source/GstUDPSink:udpsink0:
Invalid address family (got 10)
Error: gst-core-error-quark: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure. (4): gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin-0/GstRTSPSrc:source/GstUDPSink:udpsink0:
Failed to start
Error: gst-resource-error-quark: Could not get/set settings from/on resource. (13): gstmultiudpsink.c(1285): gst_multiudpsink_configure_client (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin-0/GstRTSPSrc:source/GstUDPSink:udpsink2:
Error: gst-core-error-quark: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure. (4): gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin-0/GstRTSPSrc:source/GstUDPSink:udpsink2:
Failed to start
Warning: gst-resource-error-quark: Could not read from resource. (9): gstrtspsrc.c(5769): gst_rtspsrc_reconnect (): /GstPipeline:pipeline0/GstURIDecodeBin:uridecodebin-0/GstRTSPSrc:source:
Could not receive any UDP packets for 5.0000 seconds, maybe your firewall is blocking it. Retrying using a tcp connection.
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
video connect success ********************** 0
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
reference in DPB was never decoded
NVDEC_COMMON: NvDecGetSurfPinHandle : Surface not registered
H264: Profile = 66, Level = 0
NVMEDIA: Need to set EMC bandwidth : 705000
NVMEDIA_ENC: bBlitMode is set to TRUE
add video source rtsp://localhost:8555/live/201 1
add video source rtsp://localhost:8555/live/301 2
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one.
