Nx module will / boot / extlinux/ extlinux.conf After deleting all the quiet root = / dev / mmcblk0p1 in, it can’t be started up. How can I enter the bash interface to recover
Why do you delete root=/dev/mmmcblk0p1? That will cause kernel not able to mount the file system…
Only limited commands are feasible in bash shell.
You can check this post to get a command to add this back.
Hello, the device can’t enter the graphical interface. I thought the space was full. Then I entered the system through debugging the serial port and found that it wasn’t full. I deleted it by mistake extlinux.conf , resulting in the system does not work, finished, I follow your method system up, but still can not be graphical
I am not sure the cause. Is it okay to reflash your board?
If you hit such issue again, tell us your steps to reproduce this issue.
I implemented sudo apt get update & sudo apt get upgrade through serial port
Hello, can’t TX2 enter the same wayUploading: image.png…
Do you have other modules to flash?
If yes, try it on them and see if you can see same issue.
[quote=“WayneWWW, post:9, topic:165703, full:true”]
[/quote]I can’t start it all of a sudden. I want to use the method you gave me last time. I don’t know if it’s OK
Forget about that. Just reflash the board and it will save your time…
