But, the NX is not able to detect a plain ext4 formatted SD card. The SD card is working on other Ubuntu machines, so I believe the issue is with the reader itself. The user mentions editing/replacing the standard dtb file. From other posts, it seems that the sdhci for sdmmc3 is sometimes disabled, so i’m assuming that the dtb file modification enables that?
I checked /proc/ on my jetson and saw that sdhci@3440000 and sdhci@3400000 were disabled and sdhci@3460000 is enabled. I’m using Jetpack 4.6.2, and the dtb file being flashed is the “tegra194-p3668-all-p3509-0000.dtb”. I decompiled it and saw that both 3400… and 34400… had their status set to “disabled”.
My question is: do I just set sdhci@34400… to “okay”, replace the original dtb file, and reflash?
But instead of the given flash command, flash with something like this: sudo BOOTDEV=mmcblk1p1 ./flash.sh -C nv-auto-config jetson-xavier-nx-devkit-emmc mmcblk1p1 where mmcblk1p1 is the SD card. It worked for me.
