I have a Photon carrier board and production NX that auto shuts down at about 65C.
Before the shutdown, I can see these reports of soctherm: OC ALARM 0x00000001. I am using a 12V 10Amp power supply. I guess it shouldn’t be shutting down at 65 deg if the carrier board spec says 85 C and nvidia spec says 90 C. So presumably it’s a power issue.
Could some of the system throttling cause an increase in power consumption which tips the system over the edge with a supply that it already complains is insufficient?
The fan remains at a constant manual speed throughout.
In the past, when I’ve had unwanted shutdown issues, they typically happened at the moment my inference app started. These instances were resolved by using a voltage at the higher end of the carrier board input band. However, the photon only supports 12v +5% so I’d have to find a 12.6v supply (if lack of sufficient voltage is the issue).
571.987684] soctherm: OC ALARM 0x00000001
[ 573.008026] soctherm: OC ALARM 0x00000001
[ 573.905596] FAN rising trip_level:1 cur_temp:59400 trip_temps[2]:60000
[ 574.046187] soctherm: OC ALARM 0x00000001
[ 575.021423] FAN rising trip_level:1 cur_temp:59600 trip_temps[2]:60000
[ 575.098128] soctherm: OC ALARM 0x00000001
[ 576.112792] soctherm: OC ALARM 0x00000001
[ 577.158267] soctherm: OC ALARM 0x00000001
[ 578.170506] soctherm: OC ALARM 0x00000001
[ 578.381247] FAN rising trip_level:1 cur_temp:59550 trip_temps[2]:60000
[ 579.206227] soctherm: OC ALARM 0x00000001
[ 579.501224] FAN rising trip_level:1 cur_temp:59600 trip_temps[2]:60000
[ 580.227430] soctherm: OC ALARM 0x00000001
[ 581.273666] soctherm: OC ALARM 0x00000001
[ 581.741196] FAN rising trip_level:1 cur_temp:59750 trip_temps[2]:60000
