Hi expert,
where can i find to change spi timming on NX module?
Best regards.
Peter
Hi expert,
Best regards.
Peter
Not sure exactly what timing you want.
Have a reference to below to check if any device tree configure as your expect.
Hi Shane,
We want to tune the clock data delay. I just check the link:
nvidia,enable-hw-based-cs;
nvidia,cs-setup-clk-count = <10>;
nvidia,cs-hold-clk-count = <10>;
nvidia,rx-clk-tap-delay = <0>;
nvidia,tx-clk-tap-delay = <16>;
It seems it adjusts the delay, where can I find the registers in NX manual.
Best regards
Peter
Download the TRM from download center.
Hello Shane,
In TRM, we found TX and RX delay tunning. Where can we find the physical meaning of these delay in timing chart?
Best regards
Peter
Please have check the kernel driver …/kernel/kernel-4.9/drivers/spi/spi-tegra114.c
Thank you, Shane.
I saw the default tx/rx delay (0/10), but i can’t judge it’s reasonable or not.
#define SPI_DMA_TIMEOUT (msecs_to_jiffies(10000))
#define DEFAULT_SPI_DMA_BUF_LEN (161024)
#define TX_FIFO_EMPTY_COUNT_MAX SPI_TX_FIFO_EMPTY_COUNT(0x40)
#define RX_FIFO_FULL_COUNT_ZERO SPI_RX_FIFO_FULL_COUNT(0)
#define MAX_HOLD_CYCLES 16
#define SPI_DEFAULT_SPEED 25000000
#define SPI_SPEED_TAP_DELAY_MARGIN 35000000
#define SPI_POLL_TIMEOUT 10000
#define SPI_DEFAULT_RX_TAP_DELAY 10
#define SPI_DEFAULT_TX_TAP_DELAY 0
#define SPI_FIFO_FLUSH_MAX_DELAY 2000
#define AUTOSUSPEND_TIMEOUT 300 / in millisec */
Best regards
Peter
