I’m using jetpack 4.4
Building an engine from file ctdet_hardnet_68_480x480.onnx; this may take a while…
[TensorRT] ERROR: …/builder/cudnnBuilderUtils.cpp (427) - Cuda Error in findFastestTactic: 700 (an illegal memory access was encountered)
[TensorRT] ERROR: …/rtSafe/safeRuntime.cpp (32) - Cuda Error in free: 700 (an illegal memory access was encountered)
terminate called after throwing an instance of ‘nvinfer1::CudaError’
what(): std::exception
Aborted (core dumped)
You can find the onnx file here:
I have encountered a very similar error from a previous post.
From my experiments it seems to be from the groups parameter in the Conv2D.
When will the next version come out and what exactly is causing this?
