Python 3.6.9 (default, Mar 15 2022, 13:55:28)
[GCC 8.4.0] on linux
Type “help”, “copyright”, “credits” or “license” for more information.
import tensorrt
tensorrt.version
File “”, line 1, in
AttributeError: module ‘tensorrt’ has no attribute ‘version ’
how to fix?
kayccc
May 4, 2022, 11:49pm
#2
when i convert .onnx to .engine on jetson nx, process as below, it
said " Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
terminate called after throwing an instance of ‘std::out_of_range’
what(): Attribute not found: axes"
please info me how to solve this.
/usr/src/tensorrt/bin/trtexec --onnx=best.onnx
&&&& RUNNING TensorRT.trtexec # /usr/src/tensorrt/bin/trtexec --onnx=best.onnx
[05/05/2022-15:50:18] [I] === Model Options ===
[05/05/2022-15:50:18] [I] Format: ONNX
[05/05/2022-15:50:18] [I] Model: best.onnx
[05/05/2022-15:50:18] [I] Output:
[05/05/2022-15:50:18] [I] === Build Options ===
[05/05/2022-15:50:18] [I] Max batch: 1
[05/05/2022-15:50:18] [I] Workspace: 16 MB
[05/05/2022-15:50:18] [I] minTiming: 1
[05/05/2022-15:50:18] [I] avgTiming: 8
[05/05/2022-15:50:18] [I] Precision: FP32
[05/05/2022-15:50:18] [I] Calibration:
[05/05/2022-15:50:18] [I] Safe mode: Disabled
[05/05/2022-15:50:18] [I] Save engine:
[05/05/2022-15:50:18] [I] Load engine:
[05/05/2022-15:50:18] [I] Builder Cache: Enabled
[05/05/2022-15:50:18] [I] NVTX verbosity: 0
[05/05/2022-15:50:18] [I] Inputs format: fp32:CHW
[05/05/2022-15:50:18] [I] Outputs format: fp32:CHW
[05/05/2022-15:50:18] [I] Input build shapes: model
[05/05/2022-15:50:18] [I] Input calibration shapes: model
[05/05/2022-15:50:18] [I] === System Options ===
[05/05/2022-15:50:18] [I] Device: 0
[05/05/2022-15:50:18] [I] DLACore:
[05/05/2022-15:50:18] [I] Plugins:
[05/05/2022-15:50:18] [I] === Inference Options ===
[05/05/2022-15:50:18] [I] Batch: 1
[05/05/2022-15:50:18] [I] Input inference shapes: model
[05/05/2022-15:50:18] [I] Iterations: 10
[05/05/2022-15:50:18] [I] Duration: 3s (+ 200ms warm up)
[05/05/2022-15:50:18] [I] Sleep time: 0ms
[05/05/2022-15:50:18] [I] Streams: 1
[05/05/2022-15:50:18] [I] ExposeDMA: Disabled
[05/05/2022-15:50:18] [I] Spin-wait: Disabled
[05/05/2022-15:50:18] [I] Multithreading: Disabled
[05/05/2022-15:50:18] [I] CUDA Graph: Disabled
[05/05/2022-15:50:18] [I] Skip inference: Disabled
[05/05/2022-15:50:18] [I] Inputs:
[05/05/2022-15:50:18] [I] === Reporting Options ===
[05/05/2022-15:50:18] [I] Verbose: Disabled
[05/05/2022-15:50:18] [I] Averages: 10 inferences
[05/05/2022-15:50:18] [I] Percentile: 99
[05/05/2022-15:50:18] [I] Dump output: Disabled
[05/05/2022-15:50:18] [I] Profile: Disabled
[05/05/2022-15:50:18] [I] Export timing to JSON file:
[05/05/2022-15:50:18] [I] Export output to JSON file:
[05/05/2022-15:50:18] [I] Export profile to JSON file:
kayccc
May 5, 2022, 11:58pm
#4
system
closed
May 19, 2022, 11:59pm
#5
