I tried to update NX’s device tree but failed,What went wrong, please.
sudo ./flash.sh -r -k kernel-dtb jetson-xavier-nx-devkit-emmc mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 6.1
# Target Board Information:
# Name: jetson-xavier-nx-devkit-emmc, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0041 ] Generating RCM messages
[ 0.0055 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/mb1_t194_prod.bin zerosbk
[ 0.0078 ] Header already present for /home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/mb1_t194_prod.bin
[ 0.0119 ]
[ 0.0157 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0159 ] Assuming zero filled SBK key
[ 0.0194 ] tegrasign_v3.py --file /home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[ 0.0195 ] Assuming zero filled SBK key
[ 0.0343 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin /home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[ 0.0392 ]
[ 0.0439 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[ 0.0458 ]
[ 0.0535 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/mb1_t194_prod_sigheader.bin 0 0
[ 0.0547 ] RCM 0 is saved as rcm_0.rcm
[ 0.0578 ] RCM 1 is saved as rcm_1.rcm
[ 0.0578 ] RCM 2 is saved as rcm_2.rcm
[ 0.0578 ] List of rcm files are saved in rcm_list.xml
[ 0.0578 ]
[ 0.0578 ] Signing RCM messages
[ 0.0603 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0604 ] Assuming zero filled SBK key
[ 0.0719 ] Copying signature to RCM mesages
[ 0.0733 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[ 0.0776 ]
[ 0.0779 ] Boot Rom communication
[ 0.0813 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0830 ] RCM version 0X190001
[ 0.0853 ] Boot Rom communication completed
[ 1.1316 ]
[ 2.1361 ] tegrarcm_v2 --isapplet
[ 2.1370 ] Applet version 01.00.0000
[ 2.2073 ]
[ 2.2109 ] tegrarcm_v2 --ismb2
[ 2.2892 ]
[ 2.2938 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[ 2.2977 ]
[ 2.3007 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[ 2.3026 ] adding BCH for nvtboot_applet_t194.bin
[ 2.3053 ]
[ 2.3110 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[ 2.3111 ] Assuming zero filled SBK key
[ 2.3189 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[ 2.3257 ]
[ 2.3287 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[ 2.3301 ] Applet version 01.00.0000
[ 2.3992 ] Sending mb2
[ 2.3993 ] [................................................] 100%
[ 2.4904 ]
[ 2.4934 ] tegrarcm_v2 --boot recovery
[ 2.4977 ] Applet version 01.00.0000
[ 2.5927 ]
[ 3.5986 ] tegrarcm_v2 --isapplet
[ 3.6706 ]
[ 3.6755 ] tegrarcm_v2 --ismb2
[ 3.6765 ] MB2 Applet version 01.00.0000
[ 3.7449 ]
[ 3.7473 ] tegrarcm_v2 --ismb2
[ 3.7481 ] MB2 Applet version 01.00.0000
[ 3.8126 ]
[ 3.8154 ] Retrieving board information
[ 3.8180 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[ 3.8188 ] MB2 Applet version 01.00.0000
[ 3.9493 ] Saved platform info in chip_info.bin
[ 3.9940 ] Chip minor revision: 2
[ 3.9946 ] Bootrom revision: 0xf
[ 3.9951 ] Ram code: 0x0
[ 3.9953 ] Chip sku: 0xde
[ 3.9953 ] Chip Sample: non es
[ 4.0183 ]
[ 4.0189 ] Retrieving EEPROM data
[ 4.0190 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/cvm.bin
[ 4.0205 ] MB2 Applet version 01.00.0000
[ 4.1519 ] Saved platform info in /home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/cvm.bin
[ 4.2621 ]
[ 4.2622 ] Rebooting to recovery mode
[ 4.2669 ] tegrarcm_v2 --ismb2
[ 4.2699 ] MB2 Applet version 01.00.0000
[ 4.3322 ]
[ 4.3323 ] Rebooting to recovery mode
[ 4.3357 ] tegrarcm_v2 --reboot recovery
[ 4.3367 ] MB2 Applet version 01.00.0000
[ 4.5046 ]
Board ID(3668) version(300) sku(0000) revision(B.0)
copying bctfile(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p3668-0001-a00.cfg)... done.
copying bctfile1(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying device_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-qspi-p3668.cfg)... done.
copying misc_cold_boot_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p3668-a01.cfg)... done.
copying gpioint_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p3668-0001-a00.cfg)... done.
copying pmic_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p3668-0001-a00.cfg)... done.
copying pmc_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p3668-a01.cfg)... done.
copying prod_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra19x-mb1-prod-p3668-0001-a00.cfg)... done.
copying scr_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying scr_cold_boot_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini-p3668.cfg)... done.
copying bootrom_config(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p3668-0001-a00.cfg)... done.
copying dev_params(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-br-bct-qspi.cfg)... done.
Existing bootloader(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
cp: cannot stat '/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/tegra194-mb1-bct-ratchet-p3668.cfg': No such file or directory
/home/jetson/Documents/TX2SDK/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x19 --key --minratchet_config tegra194-mb1-bct-ratchet-p3668.cfg --cmd sign boot.img kernel
version 1.0.0
[ 0.0006 ] Generating signature
[ 0.0039 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0040 ] Assuming zero filled SBK key : not reading
[ 0.0039 ] Generating ratchet blob
[ 0.0074 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0091 ] Empty File tegra194-mb1-bct-ratchet-p3668.cfg
[ 0.0093 ] Failed to Parse file tegra194-mb1-bct-ratchet-p3668.cfg: 0x0000000a
[ 0.0093 ] File tegra194-mb1-bct-ratchet-p3668.cfg open failed
[ 0.0093 ]
Error: Return value 19
Command tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p3668.cfg
l4t_sign_image.sh: Error: Unable to find the signed file generated by tegraflash.py
failed.
