OAK-D Pro W + Jetson Orin Nano Super 8GB: recommended configuration for Isaac ROS visual SLAM?
Hi everyone,
I’m developing Project Soul, a self-balancing robot for my electrical engineering thesis. A separate STM32 handles balancing, cliff sensors, suspension-position sensors and motor control. The Jetson will handle perception, navigation and a small local voice assistant.
Before purchasing the camera, I’d like to confirm this proposed configuration:
  • Jetson Orin Nano Super 8GB
  • OAK-D Pro W, USB version, with IR illumination
  • IMX378 central RGB camera and OV9282 global-shutter stereo pair
  • Externally powered USB 3 hub
  • Separate 2D LiDAR
I found NVIDIA’s OAK-D PyCuVSLAM example:
https://github.com/nvidia-isaac/cuVSLAM/tree/main/examples/oak-d
Could you clarify:
  1. Which software versions and integration path would you recommend for using this camera with Isaac ROS visual SLAM?
  2. Is the IMX378 RGB variant suitable when tracking uses the monochrome stereo pair?
  3. Are there recommended settings for resolution, frame rate, calibration, timestamps and IMU integration?
  4. Should the IR dot projector be disabled during visual tracking?
  5. Are there known limitations when the camera pitches with a balancing robot or shares the GPU with other inference workloads?
I have not finalized the software versions yet and would appreciate a tested configuration or example.
Thank you!
Hello @Adam.Ha,
Welcome to the Isaac ROS forum and thanks for sharing your project!
To answer your questions, a reasonable starting point would be:
  1. Software/integration: You could follow the Isaac ROS setup guide ( Getting Started — Isaac ROS ) for a matching JetPack/ROS stack, and confirm your DepthAI ROS driver supports it. The PyCuVSLAM example is separate from the Isaac ROS integration. Integrating the camera into Isaac ROS requires supplying stereo images, corresponding CameraInfo and camera transforms.
  2. Initial camera settings: The official OAK-D example uses unrectified monochrome images at 1280×720 and 30 FPS, with calibration read from the camera. Start there, preserve synchronized capture timestamps, and ensure calibration matches the selected resolution. The cuVSLAM documentation explains image inputs, rectification and IMU parameters. I would recommend validating stereo-only tracking before adding IMU fusion.
  3. IR: I suggest starting with the dot projector disabled for visual tracking. Diffuse IR illumination is separate and can be evaluated independently for low-light operation.
  4. Pitch/workloads: Keep ground constraints disabled for the pitching robot. Minimize vibration and motion blur, then add inference workloads gradually while monitoring frame drops, latency and memory. See the robot setup validation guide ( Validating Isaac ROS Visual SLAM on a Robot — Isaac ROS ).
Hi @vchuang
Thank you for the detailed guidance and links! That clears up the distinction between the PyCuVSLAM example and integrating the camera into Isaac ROS.
I’m still building the robot’s hardware. Once I reach testing, I’ll start with synchronized stereo-only tracking at 1280×720 and 30 FPS, matching calibration and preserved capture timestamps, with the dot projector disabled.
Since the robot pitches while balancing, I’ll keep the ground constraints disabled. The balancing loop will run independently on an STM32, while the Jetson handles perception, navigation and the assistant features.
I’ll update this thread with the exact camera configuration, software versions and results once I can test the setup. Thanks again for helping me establish a starting point!
Thanks for the update and good luck with your project!
