Obb model in Deepstream
• Hardware Platform (Jetson / GPU) Jetson Orin NX
• DeepStream Version 7.1
• JetPack Version (valid for Jetson only) L4T: 36.4.7
• TensorRT Version 10.3.0.30
• NVIDIA GPU Driver Version (valid for GPU only) CUDA 12.6.68
I tries to use yolo11s model in Deepstream and it works well.
But now, in my scenario I want to use yolo11s obb model,
and I saw the topic Deepstream && obb implementation .
Does NVIDIA have supported obb model in Deepstream now?
Or can you support me to finisih this task?
Because I tried to modify Deepstream-Yolo code by Cursor (adding one dimension of angle),
but the generated model can’t detect anything.
Thank you.
No. OBB model is not supported in current DeepStream. But this feature is in our roadmap, please wait for the future releases.
Hi Fiona,
Thanks for your reply.
Is it possible that I modify the Deepstream-Yolo library to achieve the task?
Or there are some NVIDIA’s confidential documents to be modified?
Hi, the Deepstream-Yolo is not provided by Nvidia. We can only tell you that many parts of DeepStream are open source, you can modify any open source parts to design and implement your own functions.
No confidential documents available.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
