Hello everybody!
I am trying to change the code of the gProximity library for my Master’s. My problems are on OBB tree creation. The code can create tight OBB for leafs nodes without problems but when it tries to create a parent based on children OBBs parts of them are not being bounded entirely. The relevant code for intern nodes creation is shown below as the class definition. Any help would be very appreciated.
__device__ __inline__ void init(OBB &bv1, OBB &bv2)
// somewhat based on code from Dave Eberly / geometrictools.com
// guess at center by taking middle
center = f3v_add(bv1.center, bv2.center);
center = f3v_mul1(center, 0.5f);
// ASSUME: axis = axis of BV1
axis1 = bv1.axis1;
axis2 = bv1.axis2;
axis3 = bv1.axis3;
// extents as calculated from all 16 points and 3 axes
float3 minExtent = make_float3(CUDART_NORM_HUGE_F, CUDART_NORM_HUGE_F, CUDART_NORM_HUGE_F),
maxExtent = make_float3(-CUDART_NORM_HUGE_F, -CUDART_NORM_HUGE_F, -CUDART_NORM_HUGE_F);
calcExtentsForOBB(bv1, minExtent, maxExtent);
calcExtentsForOBB(bv2, minExtent, maxExtent);
float3 distCenters = f3v_sub(bv2.center , bv1.center);
float3 distCentersHalf = f3v_mul1(distCenters , 0.5);
minExtent = f3v_sub(minExtent , distCentersHalf);
maxExtent = f3v_add(maxExtent , distCentersHalf);
// [minExtent,maxExtent] is the axis-aligned box in the coordinate system of the
// merged box axes. Update the current box center to be the center of
// the new box. Compute the extents based on the new center.
float factorX = 0.5f * (maxExtent.x + minExtent.x);
float3 correctorX = f3v_mul1(axis1, factorX);
center = f3v_add(correctorX, center);
extents.x = 0.5f * (maxExtent.x - minExtent.x);
float factorY = 0.5f * (maxExtent.y + minExtent.y);
float3 correctorY = f3v_mul1(axis2, factorY);
center = f3v_add(correctorY, center);
extents.y = 0.5f * (maxExtent.y - minExtent.y);
float factorZ = 0.5f * (maxExtent.z + minExtent.z);
float3 correctorZ = f3v_mul1(axis3, factorZ);
center = f3v_add(correctorZ, center);
extents.z = 0.5f * (maxExtent.z - minExtent.z);
__host__ __device__ __inline__ void calcExtentsForOBB(OBB &bv, float3 &minExtent, float3 &maxExtent)
// generate all 8 points of OBB
bv.axis1 = f3v_mul1(bv.axis1, bv.extents.x);
bv.axis2 = f3v_mul1(bv.axis2, bv.extents.y);
bv.axis3 = f3v_mul1(bv.axis3, bv.extents.z);
float3 point, temp;
float dist;
// 1
temp = f3v_add(bv.axis1, bv.axis2);
point = f3v_add(temp, bv.axis3);
dist = f3v_dot(point, axis1);
minExtent.x = min(minExtent.x, dist);
maxExtent.x = max(maxExtent.x, dist);
dist = f3v_dot(point, axis2);
minExtent.y = min(minExtent.y, dist);
maxExtent.y = max(maxExtent.y, dist);
dist = f3v_dot(point, axis3);
minExtent.z = min(minExtent.z, dist);
maxExtent.z = max(maxExtent.z, dist);
// 2
point = f3v_sub(temp, bv.axis3);
// 3
temp = f3v_sub(bv.axis1, bv.axis2);
// 4
// 5
bv.axis1.x = -bv.axis1.x;
bv.axis1.y = -bv.axis1.y;
bv.axis1.z = -bv.axis1.z;
// 6
// 7
// 8
class OBB
public:
__host__ __device__ __inline__ void calcExtentsForOBB(OBB &bv, float3 &minExtent, float3 &maxExtent);
__host__ __device__ __inline__ void calcOBBPoints(float3 *result_points) const;
__device__ __inline__ void init(OBB &bv1, OBB &bv2);
// init OBB from triangle
__device__ __inline__ void init(const float3 &v1, const float3 &v2, const float3 &v3);
__device__ __inline__ void init(const float3 &v1, const float3 &v2, const float3 &v3, const float3 &u1, const float3 &u2, const float3 &u3);
__device__ __inline__ float getSize() const;
//Draws the box (just the side faces)
__host__ __inline__ void draw();
float3 center; // center point of OBB
float3 axis1, // major axes specifying the OBB
axis2,
axis3;
float3 extents; // extents to boundary from center point,
// along each axis
Thanks in advance,
VinÃcius da Silva.
