I followed https://medium.com/swlh/how-to-run-tensorflow-object-detection-model-on-jetson-nano-8f8c6d4352e8 steps to generate TF-TRT models for Jetson Nano. While I am able to generate the TRT models using Google Colab, I am facing problem in deploying those models in Nano.
While loading TensorRT graph using the code
import tensorflow as tf
def get_frozen_graph(graph_file):
"""Read Frozen Graph file from disk."""
with tf.gfile.FastGFile(graph_file, "rb") as f:
graph_def = tf.GraphDef()
graph_def.ParseFromString(f.read())
return graph_def
# The TensorRT inference graph file downloaded from Colab or your local machine.
pb_fname = "./model/trt_graph.pb"
trt_graph = get_frozen_graph(pb_fname)
input_names = ['image_tensor']
# Create session and load graph
tf_config = tf.ConfigProto()
tf_config.gpu_options.allow_growth = True
tf_sess = tf.Session(config=tf_config)
tf.import_graph_def(trt_graph, name='')
I get the following error:
InvalidArgumentError Traceback (most recent call last)
~/.local/lib/python3.6/site-packages/tensorflow/python/framework/importer.py in import_graph_def(graph_def, input_map, return_elements, name, op_dict, producer_op_list)
425 results = c_api.TF_GraphImportGraphDefWithResults(
--> 426 graph._c_graph, serialized, options) # pylint: disable=protected-access
427 results = c_api_util.ScopedTFImportGraphDefResults(results)
InvalidArgumentError: NodeDef mentions attr 'half_pixel_centers' not in Op<name=ResizeBilinear; signature=images:T, size:int32 -> resized_images:float; attr=T:type,allowed=[DT_INT8, DT_UINT8, DT_INT16, DT_UINT16, DT_INT32, DT_INT64, DT_BFLOAT16, DT_HALF, DT_FLOAT, DT_DOUBLE]; attr=align_corners:bool,default=false>; NodeDef: {{node Preprocessor/ResizeImage/resize/ResizeBilinear}}. (Check whether your GraphDef-interpreting binary is up to date with your GraphDef-generating binary.).
During handling of the above exception, another exception occurred:
ValueError Traceback (most recent call last)
<ipython-input-4-380436e20a8b> in <module>
3 tf_config.gpu_options.allow_growth = True
4 tf_sess = tf.Session(config=tf_config)
----> 5 tf.import_graph_def(trt_graph, name='')
~/.local/lib/python3.6/site-packages/tensorflow/python/util/deprecation.py in new_func(*args, **kwargs)
505 'in a future version' if date is None else ('after %s' % date),
506 instructions)
--> 507 return func(*args, **kwargs)
508
509 doc = _add_deprecated_arg_notice_to_docstring(
428 except errors.InvalidArgumentError as e:
429 # Convert to ValueError for backwards compatibility.
--> 430 raise ValueError(str(e))
431
432 # Create _DefinedFunctions for any imported functions.
ValueError: NodeDef mentions attr 'half_pixel_centers' not in Op<name=ResizeBilinear; signature=images:T, size:int32 -> resized_images:float; attr=T:type,allowed=[DT_INT8, DT_UINT8, DT_INT16, DT_UINT16, DT_INT32, DT_INT64, DT_BFLOAT16, DT_HALF, DT_FLOAT, DT_DOUBLE]; attr=align_corners:bool,default=false>; NodeDef: {{node Preprocessor/ResizeImage/resize/ResizeBilinear}}. (Check whether your GraphDef-interpreting binary is up to date with your GraphDef-generating binary.).
I search Stackoverflow for GraphDef issue. It says to downgrade the Tensorflow version to resolve it, but since NVIDIA is providing the Tensorflow version for Jetson Nano, we can’t do that.
Is there a way around for this issue?
