I set up Yolov3 like on this page: Darknet Yolo and everything works but while tried to run Real-Time Detection on a Webcam with
./darknet detector demo cfg/coco.data cfg/yolov3.cfg yolov3.weights
it doesn’t work.
it doesn’t work.
Your error messages would be helpful to get hint.
after run this code, the error is: Demo needs OpenCV for webcam images.
there is only this. nothing else.
Are u using a CSI camera or an USB webcam?
If you have a CSI camera, follow this command:
USB, trying ZED camera
Please remember to enable the openCV flag to launch the demo application.
For example. if you are using this GitHub, please apply the following two change:
From 437eab747cc076c67d9299a5df586290741b1ec6 Mon Sep 17 00:00:00 2001
Date: Wed, 6 May 2020 11:44:41 +0800
Subject: [PATCH] bug 200614143
Makefile | 16 ++++++-------
src/image_opencv.cpp | 56 ++++++++++++++++----------------------------
2 files changed, 27 insertions(+), 45 deletions(-)
diff --git a/Makefile b/Makefile
index 63e15e6..9a7471d 100644
--- a/Makefile
+++ b/Makefile
@@ -1,13 +1,11 @@
-GPU=0
-CUDNN=0
-OPENCV=0
+GPU=1
+CUDNN=1
+OPENCV=1
OPENMP=0
DEBUG=0
-ARCH= -gencode arch=compute_30,code=sm_30 \
- -gencode arch=compute_35,code=sm_35 \
- -gencode arch=compute_50,code=[sm_50,compute_50] \
- -gencode arch=compute_52,code=[sm_52,compute_52]
+ARCH= -gencode arch=compute_62,code=sm_62 \
+ -gencode arch=compute_62,code=[sm_62,compute_62]
# -gencode arch=compute_20,code=[sm_20,sm_21] \ This one is deprecated?
# This is what I use, uncomment if you know your arch and want to specify
@@ -42,8 +40,8 @@ CFLAGS+=$(OPTS)
ifeq ($(OPENCV), 1)
COMMON+= -DOPENCV
CFLAGS+= -DOPENCV
-LDFLAGS+= `pkg-config --libs opencv` -lstdc++
-COMMON+= `pkg-config --cflags opencv`
+LDFLAGS+= `pkg-config --libs opencv4` -lstdc++
+COMMON+= `pkg-config --cflags opencv4`
endif
ifeq ($(GPU), 1)
diff --git a/src/image_opencv.cpp b/src/image_opencv.cpp
index 7511280..c11805a 100644
--- a/src/image_opencv.cpp
+++ b/src/image_opencv.cpp
@@ -9,30 +9,34 @@ using namespace cv;
extern "C" {
-IplImage *image_to_ipl(image im)
+Mat image_to_mat(image im)
+ assert(im.c == 3 || im.c == 1);
int x,y,c;
- IplImage *disp = cvCreateImage(cvSize(im.w,im.h), IPL_DEPTH_8U, im.c);
- int step = disp->widthStep;
+ image copy = copy_image(im);
+ constrain_image(copy);
+ if(im.c == 3) rgbgr_image(copy);
+ Mat m(im.h, im.w, CV_MAKETYPE(CV_8U, im.c));
for(y = 0; y < im.h; ++y){
for(x = 0; x < im.w; ++x){
for(c= 0; c < im.c; ++c){
- float val = im.data[c*im.h*im.w + y*im.w + x];
- disp->imageData[y*step + x*im.c + c] = (unsigned char)(val*255);
+ float val = copy.data[c*im.h*im.w + y*im.w + x];
+ m.data[y*im.w*im.c + x*im.c + c] = (unsigned char)(val*255);
- return disp;
+ free_image(copy);
+ return m;
-image ipl_to_image(IplImage* src)
+image mat_to_image(Mat m)
- int h = src->height;
- int w = src->width;
- int c = src->nChannels;
+ int h = m.rows;
+ int w = m.cols;
+ int c = m.channels();
image im = make_image(w, h, c);
- unsigned char *data = (unsigned char *)src->imageData;
- int step = src->widthStep;
+ unsigned char *data = (unsigned char*)m.data;
+ int step = m.step;
int i, j, k;
for(i = 0; i < h; ++i){
@@ -42,26 +46,6 @@ image ipl_to_image(IplImage* src)
- return im;
-Mat image_to_mat(image im)
- image copy = copy_image(im);
- constrain_image(copy);
- if(im.c == 3) rgbgr_image(copy);
- IplImage *ipl = image_to_ipl(copy);
- Mat m = cvarrToMat(ipl, true);
- cvReleaseImage(&ipl);
- free_image(copy);
- return m;
-image mat_to_image(Mat m)
- IplImage ipl = m;
- image im = ipl_to_image(&ipl);
rgbgr_image(im);
return im;
@@ -72,9 +56,9 @@ void *open_video_stream(const char *f, int c, int w, int h, int fps)
if(f) cap = new VideoCapture(f);
else cap = new VideoCapture(c);
if(!cap->isOpened()) return 0;
- if(w) cap->set(CV_CAP_PROP_FRAME_WIDTH, w);
- if(h) cap->set(CV_CAP_PROP_FRAME_HEIGHT, w);
- if(fps) cap->set(CV_CAP_PROP_FPS, w);
+ if(w) cap->set(CAP_PROP_FRAME_WIDTH, w);
+ if(h) cap->set(CAP_PROP_FRAME_HEIGHT, w);
+ if(fps) cap->set(CAP_PROP_FPS, w);
return (void *) cap;
@@ -123,7 +107,7 @@ void make_window(char *name, int w, int h, int fullscreen)
namedWindow(name, WINDOW_NORMAL);
if (fullscreen) {
- setWindowProperty(name, CV_WND_PROP_FULLSCREEN, CV_WINDOW_FULLSCREEN);
+ setWindowProperty(name, WND_PROP_FULLSCREEN, WINDOW_FULLSCREEN);
} else {
resizeWindow(name, w, h);
if(strcmp(name, "Demo") == 0) moveWindow(name, 0, 0);
2.17.1
From 816ec5889d7f43a3486021868096ec5576b9eb09 Mon Sep 17 00:00:00 2001
Date: Fri, 10 Jul 2020 12:15:07 +0800
Subject: [PATCH] fix for cudnn_v8 (limited memory to default darknet setting)
src/convolutional_layer.c | 74 +++++++++++++++++++++++++++++++++++++++
1 file changed, 74 insertions(+)
diff --git a/src/convolutional_layer.c b/src/convolutional_layer.c
index 1fb58b0..f950c01 100644
--- a/src/convolutional_layer.c
+++ b/src/convolutional_layer.c
@@ -8,6 +8,9 @@
#include <stdio.h>
#include <time.h>
+#define PRINT_CUDNN_ALGO 0
+#define MEMORY_LIMIT 2000000000
#ifdef AI2
#include "xnor_layer.h"
#endif
@@ -145,6 +148,76 @@ void cudnn_convolutional_setup(layer *l)
#endif
+ #if CUDNN_MAJOR >= 8
+ int returnedAlgoCount;
+ cudnnConvolutionFwdAlgoPerf_t fw_results[2 * CUDNN_CONVOLUTION_FWD_ALGO_COUNT];
+ cudnnConvolutionBwdDataAlgoPerf_t bd_results[2 * CUDNN_CONVOLUTION_BWD_DATA_ALGO_COUNT];
+ cudnnConvolutionBwdFilterAlgoPerf_t bf_results[2 * CUDNN_CONVOLUTION_BWD_FILTER_ALGO_COUNT];
+ cudnnFindConvolutionForwardAlgorithm(cudnn_handle(),
+ l->srcTensorDesc,
+ l->weightDesc,
+ l->convDesc,
+ l->dstTensorDesc,
+ CUDNN_CONVOLUTION_FWD_ALGO_COUNT,
+ &returnedAlgoCount,
+ fw_results);
+ for(int algoIndex = 0; algoIndex < returnedAlgoCount; ++algoIndex){
+ #if PRINT_CUDNN_ALGO > 0
+ printf("^^^^ %s for Algo %d: %f time requiring %llu memory\n",
+ cudnnGetErrorString(fw_results[algoIndex].status),
+ fw_results[algoIndex].algo, fw_results[algoIndex].time,
+ (unsigned long long)fw_results[algoIndex].memory);
+ #endif
+ if( fw_results[algoIndex].memory < MEMORY_LIMIT ){
+ l->fw_algo = fw_results[algoIndex].algo;
+ break;
+ cudnnFindConvolutionBackwardDataAlgorithm(cudnn_handle(),
+ l->weightDesc,
+ l->ddstTensorDesc,
+ l->convDesc,
+ l->dsrcTensorDesc,
+ CUDNN_CONVOLUTION_BWD_DATA_ALGO_COUNT,
+ bd_results);
+ cudnnGetErrorString(bd_results[algoIndex].status),
+ bd_results[algoIndex].algo, bd_results[algoIndex].time,
+ (unsigned long long)bd_results[algoIndex].memory);
+ #endif
+ if( bd_results[algoIndex].memory < MEMORY_LIMIT ){
+ l->bd_algo = bd_results[algoIndex].algo;
+ break;
+ cudnnFindConvolutionBackwardFilterAlgorithm(cudnn_handle(),
+ l->srcTensorDesc,
+ l->convDesc,
+ l->dweightDesc,
+ CUDNN_CONVOLUTION_BWD_FILTER_ALGO_COUNT,
+ bf_results);
+ cudnnGetErrorString(bf_results[algoIndex].status),
+ bf_results[algoIndex].algo, bf_results[algoIndex].time,
+ (unsigned long long)bf_results[algoIndex].memory);
+ #endif
+ if( bf_results[algoIndex].memory < MEMORY_LIMIT ){
+ l->bf_algo = bf_results[algoIndex].algo;
+ break;
+ #else
cudnnGetConvolutionForwardAlgorithm(cudnn_handle(),
l->srcTensorDesc,
l->weightDesc,
@@ -169,6 +242,7 @@ void cudnn_convolutional_setup(layer *l)
CUDNN_CONVOLUTION_BWD_FILTER_SPECIFY_WORKSPACE_LIMIT,
2000000000,
&l->bf_algo);
+ #endif
#endif
#endif
2.17.1
i tried it from Darknet Yolo
and i activated GPU, CUDNN, OPENCV and then make
beforehand
but it shows me
sadsavunma@sadsavunma-desktop:/media/sadsavunma/SD/darknet$ make
gcc -Iinclude/ -Isrc/ -DOPENCV `pkg-config --cflags opencv` -DGPU -I/usr/local/cuda/include/ -DCUDNN -Wall -Wno-unused-result -Wno-unknown-pragmas -Wfatal-errors -fPIC -Ofast -DOPENCV -DGPU -DCUDNN -c ./src/gemm.c -o obj/gemm.o
Package opencv was not found in the pkg-config search path.
Perhaps you should add the directory containing `opencv.pc'
to the PKG_CONFIG_PATH environment variable
No package 'opencv' found
./src/gemm.c: In function ‘time_gpu’:
./src/gemm.c:232:9: warning: ‘cudaThreadSynchronize’ is deprecated [-Wdeprecated-declarations]
cudaThreadSynchronize();
In file included from /usr/local/cuda/include/cuda_runtime.h:96:0,
from include/darknet.h:11,
from ./src/utils.h:5,
from ./src/gemm.c:2:
/usr/local/cuda/include/cuda_runtime_api.h:957:57: note: declared here
extern __CUDA_DEPRECATED __host__ cudaError_t CUDARTAPI cudaThreadSynchronize(void);
gcc -Iinclude/ -Isrc/ -DOPENCV `pkg-config --cflags opencv` -DGPU -I/usr/local/cuda/include/ -DCUDNN -Wall -Wno-unused-result -Wno-unknown-pragmas -Wfatal-errors -fPIC -Ofast -DOPENCV -DGPU -DCUDNN -c ./src/utils.c -o obj/utils.o
gcc -Iinclude/ -Isrc/ -DOPENCV `pkg-config --cflags opencv` -DGPU -I/usr/local/cuda/include/ -DCUDNN -Wall -Wno-unused-result -Wno-unknown-pragmas -Wfatal-errors -fPIC -Ofast -DOPENCV -DGPU -DCUDNN -c ./src/cuda.c -o obj/cuda.o
gcc -Iinclude/ -Isrc/ -DOPENCV `pkg-config --cflags opencv` -DGPU -I/usr/local/cuda/include/ -DCUDNN -Wall -Wno-unused-result -Wno-unknown-pragmas -Wfatal-errors -fPIC -Ofast -DOPENCV -DGPU -DCUDNN -c ./src/deconvolutional_layer.c -o obj/deconvolutional_layer.o
gcc -Iinclude/ -Isrc/ -DOPENCV `pkg-config --cflags opencv` -DGPU -I/usr/local/cuda/include/ -DCUDNN -Wall -Wno-unused-result -Wno-unknown-pragmas -Wfatal-errors -fPIC -Ofast -DOPENCV -DGPU -DCUDNN -c ./src/convolutional_layer.c -o obj/convolutional_layer.o
./src/convolutional_layer.c: In function ‘cudnn_convolutional_setup’:
./src/convolutional_layer.c:148:5: warning: implicit declaration of function ‘cudnnGetConvolutionForwardAlgorithm’; did you mean ‘cudnnGetConvolutionForwardAlgorithm_v7’? [-Wimplicit-function-declaration]
./src/convolutional_layer.c:153:13: error: ‘CUDNN_CONVOLUTION_FWD_SPECIFY_WORKSPACE_LIMIT’ undeclared (first use in this function); did you mean ‘CUDNN_CONVOLUTION_FWD_ALGO_DIRECT’?
CUDNN_CONVOLUTION_FWD_SPECIFY_WORKSPACE_LIMIT,
compilation terminated due to -Wfatal-errors.
Makefile:89: recipe for target 'obj/convolutional_layer.o' failed
make: *** [obj/convolutional_layer.o] Error 1
it doesn’t work.
Based on the log, please use the opencv4 rather than opencv.
The folder for opencv v4.x.x has changed for distinguishing.
... -DOPENCV `pkg-config --cflags opencv4` ...
like this ?
+GPU=1
+CUDNN=1
+OPENCV4=1
i don’t understand i’m the new at jetson
Please update here into the following:
ifeq ($(OPENCV), 1)
COMMON+= -DOPENCV
CFLAGS+= -DOPENCV
endif
The complete detail is shared above.
It is worthy to take a look and update the darknet source with the change.
thank you
