Hi, This is my error when following this tutorial - pytorch-collect-detection.md
But I do have the .XML files in Annotation folder as you can see above, what’s going on?
Can you post the contents of your "ImageSets/Main/test.txt"
file? It seems like there is a blank image ID in there.
If you could also share your dataset so I could debug it, that would be useful. Thanks.
Interesting, thank you. Did the training proceed once you removed it?
I will add some additional checks to the train_ssd.py
scripts to avoid this error and skip lines like that.
OK, I added some additional error checking for this in commit 2d32cf
. If you pull the latest, it should avoid this condition from occurring in the future.
Yes, it starts working right after. Thanks a lot
Awesome, thanks a lot ❤
