Object Encoder is not hardware encoding
• Hardware Platform (Jetson / GPU) t4
• DeepStream Version 5.1
• TensorRT Version 7.2
• NVIDIA GPU Driver Version (valid for GPU only) 440
• Issue Type( questions, new requirements, bugs) question
I encode the image using nvds_obj_enc_process and get the correct result .But when I use the commond “nvidia-smi dmon” to check the GPU status , I found that the hardware coding unit is not used.
nvds_obj_enc_process is JPEG encoder, there is no HW JPEG encoder in T4. Video Encode and Decode GPU Support Matrix [NEW] | NVIDIA Developer
So how should I code images use hardware in DeepStream?
It is necessary to save the current frame after the target is detected
There is no HW JPEG encoder in T4.
