objectDetector_Yolo for YOLO9000
Hello everyone,
I want to adapt the code from objectDetector_Yolo to be able to use YOLO9000 [1].
I know it is based on YOLOv2 the only difference being the last layer.
YOLOv2 does a softmax where YOLO9000 does a tree like softmax (WordTree).
What do I have to modify in objectDetector_Yolo in order to be able to use YOLO9000?
Thank you in advance for your help and guidance.
[1] [url]https://pjreddie.com/media/files/papers/YOLO9000.pdf[/url]
update:
Children from each node are packed together in the tree structure [2] and
thus we can precompute the number of children in each pack [3].
Is it possible to replace the SoftMax layer from YOLOv2 by a RaggedSoftMax layer instead?
It seems to be the layer that best fit YOLO9000 requirements.
[2] [url]https://github.com/pjreddie/darknet/blob/master/data/9k.tree[/url]
[3] [url]https://drive.google.com/file/d/1wiEmMmfvC19dFIFg0nWY2i4nBdbNb0hE/view?usp=sharing[/url]
TensorRT already provides an optimized plugin layer for yolo9000’s last layer. Can you take a look at NvInferPlugin.h file in Tensorrt ?
Hi NvCJR,
From NvInferPlugin.h I found the function createRegionPlugin(…) used by both YOLOv2 and YOLO9000.
DeepStream already uses that function for YOLOv2.
One of the parameters is a pointer to the softmaxTree structure.
DeepStream (objectDetector_Yolo) sets that pointer to nullptr and
I need to build that structure.
Could you please describe a bit each part of that structure?
I found a source code that reads the tree from a file:
[url]https://github.com/pjreddie/darknet/blob/master/src/tree.c#L83-L139[/url]
It is based on the same structure used by TensorRT:
[url]https://github.com/pjreddie/darknet/blob/master/include/darknet.h#L34-L45[/url]
I just have to read the code to understand how it works.
