I am a new user of PVF. I tried to debug a code and see the variables changing during debugging, but I came a cross with something weird. Once I start debugging (from a build code), debugging does not go forward from the the first breakpoint, neither Step Into nor Step Out. Moreover I am not able to see the values of the variable allocated for the variables before the breakpoint. The only command works here is the running command which of course gives a correct result.
I take a look to the PVF user’s guide and it was written"The autos window provides information about a changing set of variables as determined by the current debugging location. This window is supported for VC++ code but will not contain any information when debugging in a Fortran source file."
I am a bit confused, as I am not able to see changing variables in the debugging process. I would appreciate if someone makes this issue clear that if one is able to see the changing variables or not with PVF, if not, any alternative within PVF?
Thanks a lot
