JetPack 6.2
MAX power mode
We found OC system warning, but system usage info is as below, we found not exceed TDP. And there is no OC warning message in serial log. What is the OC trip Amps? And what should we do to avoid OC waring?
The temperation is below 80℃.
There are 3 kinds of OC events that you could read from document first.
Instantaneous one is not able to be observed from tegrastats of jtop
Yes, we got it. If the Temperature is not so high - 80℃, instantaneous current is over hardware threshold. Why did it happen? We just use the device as normal, and temperature is normal as well.
It would trigger the throttling as the document mentioned.
