I am encountering a rare issue on my Xavier device running JetPack 4.6.4. Occasionally, during startup, the nvpmodel
service triggers a kernel panic, but restarting the device usually resolves the issue. Here are the details:
Feb 28 04:10:11 work-desktop systemd[1]: Starting nvpmodel service…
Feb 28 04:10:11 work-desktop kernel: [ 8.217029] nvgpu: 17000000.gv11b tpc_pg_mask_store:843 [INFO] no value change, same mask already set
Feb 28 04:10:12 work-desktop kernel: [ 8.226776] Unable to handle kernel paging request at virtual address dead0000000000fe
Feb 28 04:10:12 work-desktop kernel: [ 8.227007] Mem abort info:
Feb 28 04:10:12 work-desktop kernel: [ 8.227107] ESR = 0x96000004
Feb 28 04:10:12 work-desktop kernel: [ 8.227197] Exception class = DABT (current EL), IL = 32 bits
Feb 28 04:10:12 work-desktop kernel: [ 8.227334] SET = 0, FnV = 0
Feb 28 04:10:12 work-desktop kernel: [ 8.227416] EA = 0, S1PTW = 0
Feb 28 04:10:12 work-desktop kernel: [ 8.227499] Data abort info:
Feb 28 04:10:12 work-desktop kernel: [ 8.227573] ISV = 0, ISS = 0x00000004
Feb 28 04:10:12 work-desktop kernel: [ 8.227664] CM = 0, WnR = 0
Feb 28 04:10:12 work-desktop kernel: [ 8.227748] [dead0000000000fe] address between user and kernel address ranges
Feb 28 04:10:12 work-desktop dbus-daemon[5053]: [system] Successfully activated service ‘org.freedesktop.hostname1’
Feb 28 04:10:12 work-desktop kernel: [ 8.227917] Internal error: Oops: 96000004 [#1] PREEMPT SMP
Feb 28 04:10:12 work-desktop kernel: [ 8.228054] Modules linked in: binfmt_misc bluedroid_pm userspace_alert nvgpu ip_tables x_tables
Feb 28 04:10:12 work-desktop kernel: [ 8.228323] CPU: 1 PID: 5864 Comm: nvpmodel Not tainted 4.9.253-tegra #33
Feb 28 04:10:12 work-desktop kernel: [ 8.228474] Hardware name: Jetson-AGXi (DT)
Feb 28 04:10:12 work-desktop kernel: [ 8.228577] task: ffffffc6b1cfb800 task.stack: ffffffc6a1ecc000
Feb 28 04:10:12 work-desktop kernel: [ 8.228718] PC is at __dump_page+0x38/0x1d0
Feb 28 04:10:12 work-desktop kernel: [ 8.228860] LR is at dump_page+0x28/0x38
Feb 28 04:10:12 work-desktop kernel: [ 8.229141] pc : [] lr : [] pstate: 00400045
Feb 28 04:10:12 work-desktop kernel: [ 8.229684] sp : ffffffc6a1ecf7c0
Feb 28 04:10:12 work-desktop kernel: [ 8.229950] x29: ffffffc6a1ecf7c0 x28: 0000000000000008
Feb 28 04:10:12 work-desktop kernel: [ 8.234951] x27: 0000000000000100 x26: 000000000000003f
Feb 28 04:10:12 work-desktop kernel: [ 8.240797] x25: 0000000000000001 x24: 0000000000000100
Feb 28 04:10:12 work-desktop kernel: [ 8.246394] x23: ffffffc6a7dd7000 x22: 0000000000000000
Feb 28 04:10:12 work-desktop kernel: [ 8.251752] x21: ffffff80093db110 x20: 0000000000000000
Feb 28 04:10:12 work-desktop kernel: [ 8.257419] x19: ffffffbf1ac55980 x18: 0000000000000001
Feb 28 04:10:12 work-desktop kernel: [ 8.262687] x17: 0000000000001350 x16: 000000000000c608
Feb 28 04:10:12 work-desktop kernel: [ 8.268706] x15: ffffffffffffffff x14: 000000000000002d
Feb 28 04:10:12 work-desktop kernel: [ 8.274480] x13: 0000000000000001 x12: 0000000000000100
Feb 28 04:10:12 work-desktop kernel: [ 8.279927] x11: 0088000000000000 x10: 0140000000000000
Feb 28 04:10:12 work-desktop kernel: [ 8.285943] x9 : 0000000000000000 x8 : ffffffc6a7dd7800
Feb 28 04:10:12 work-desktop kernel: [ 8.291719] x7 : 0000000670a00000 x6 : 0000000000000018
Feb 28 04:10:12 work-desktop kernel: [ 8.297232] x5 : ffffff800a1a5880 x4 : ffffff800a1a5820
Feb 28 04:10:12 work-desktop kernel: [ 8.302327] x3 : dead0000000000ff x2 : 0000000000000001
Feb 28 04:10:12 work-desktop kernel: [ 8.307907] x1 : dead0000000000ff x0 : dead0000000000fe
Feb 28 04:10:12 work-desktop kernel: [ 8.313241]
Feb 28 04:10:12 work-desktop kernel: [ 8.314648] Process nvpmodel (pid: 5864, stack limit = 0xffffffc6a1ecc000)
Feb 28 04:10:12 work-desktop kernel: [ 8.321039] Call trace:
Feb 28 04:10:12 work-desktop kernel: [ 8.323668] [] __dump_page+0x38/0x1d0
Feb 28 04:10:12 work-desktop kernel: [ 8.328214] [] dump_page+0x28/0x38
Feb 28 04:10:12 work-desktop kernel: [ 8.333026] [] split_page+0xc8/0xf0
Feb 28 04:10:12 work-desktop kernel: [ 8.337841] [] __alloc_buffer_pages+0x1cc/0x2b0
Feb 28 04:10:12 work-desktop kernel: [ 8.343701] [] __dma_alloc.isra.8+0x1e0/0x388
Feb 28 04:10:12 work-desktop kernel: [ 8.349039] [] arm_coherent_dma_alloc+0xa8/0xc0
Feb 28 04:10:12 work-desktop kernel: [ 8.355446] [] nvgpu_dma_alloc_flags_sys+0x110/0x380 [nvgpu]
Feb 28 04:10:12 work-desktop kernel: [ 8.362354] [] gk20a_init_fifo_setup_sw_common+0x3b0/0x6d8 [nvgpu]
Feb 28 04:10:12 work-desktop kernel: [ 8.369615] [] gk20a_init_fifo_setup_sw+0x54/0x2a8 [nvgpu]
Feb 28 04:10:12 work-desktop kernel: [ 8.375750] [] gk20a_init_fifo_support+0x28/0x48 [nvgpu]
Feb 28 04:10:12 work-desktop kernel: [ 8.382754] [] gk20a_finalize_poweron+0x48c/0x8f0 [nvgpu]
Feb 28 04:10:12 work-desktop kernel: [ 8.389731] [] gk20a_pm_finalize_poweron+0xe4/0x418 [nvgpu]
Feb 28 04:10:12 work-desktop kernel: [ 8.397095] [] gk20a_pm_runtime_resume+0x58/0x70 [nvgpu]
Feb 28 04:10:12 work-desktop kernel: [ 8.403473] [] pm_generic_runtime_resume+0x3c/0x58
Feb 28 04:10:12 work-desktop kernel: [ 8.409856] [] __rpm_callback+0x74/0xa0
Feb 28 04:10:12 work-desktop kernel: [ 8.415540] [] rpm_callback+0x34/0x98
Feb 28 04:10:12 work-desktop kernel: [ 8.420616] [] rpm_resume+0x470/0x710
Feb 28 04:10:12 work-desktop kernel: [ 8.425860] [] pm_runtime_forbid+0x64/0x78
Feb 28 04:10:12 work-desktop kernel: [ 8.431549] [] control_store+0xf4/0x118
Feb 28 04:10:12 work-desktop kernel: [ 8.436974] [] dev_attr_store+0x44/0x60
Feb 28 04:10:12 work-desktop kernel: [ 8.442490] [] sysfs_kf_write+0x58/0x80
Feb 28 04:10:12 work-desktop kernel: [ 8.447741] [] kernfs_fop_write+0xfc/0x1e0
Feb 28 04:10:12 work-desktop kernel: [ 8.453342] [] __vfs_write+0x48/0x118
Feb 28 04:10:12 work-desktop kernel: [ 8.458761] [] vfs_write+0xac/0x1b0
Feb 28 04:10:12 work-desktop kernel: [ 8.463579] [] SyS_write+0x5c/0xc8
Feb 28 04:10:12 work-desktop kernel: [ 8.468826] [] el0_svc_naked+0x34/0x38
Feb 28 04:10:12 work-desktop kernel: [ 8.474164] —[ end trace 68a4b6346344aded ]—
What could be causing this issue? Could it be related to the nvpmodel
configuration or hardware? Are there any preventive measures or further diagnostic steps I can take?
