The following error shows up from time to time when running the nvimg_cap sample (samples/nvmedia/img_cap): iscRootDevOpen: can't open /dev/isc-mgr.0.a - Device or resource busy. A reboot of the xavier usually fixes the problem. The error shows up on different occasions:
sporadically, even directly after the start of a completely “cold” system
sporadically, after killing the sample with ctrl+c
My question would be:
Is there anything I can do to avoid a reboot and do a “soft” restart of the camera and/or de-serializer device(s)?
Is this a known issue and is there any other way to avoid it or reduce the frequency of it occurring?
I tried with SF3324 and SF3325 cameras.
DPX2 PDK Version
5.1.6.1-16902563
Software Version
Dear @sebastian.freitag1,
Please confirm if the camera is already in use by another process when you run nvmimg_cap sample?
How to reproduce the issue on our side?
Do you still see this issue. Any update can be provided on above ask? I would suggest you to check with our latest DRIVE release to see if the issue persists.
Hello, thanks for reaching out. I was able to setup some automated testing and analyze it with the following results:
It turned out to be two separate issues that just looked similar.
One instance of the issue could be explained by a process still holding the resource that did not terminate properly. A programming error on our end was the reason.
The other instance of the issue (already blocked directly after reboot) happens occasionally if we try to use the camera DIRECTLY after reboot. Just waiting a few seconds solves the problem. Initially I thought a reboot was required but that turned out NOT to be true.
Thank you for your help. Also, ‘lsof’ turned out to be a useful tool to find out what process holds a file.
