occupancy bug
I noticed a program running much more slowly than I would expect today, and I think I’ve narrowed the problem down to the occupancy being different from what is reported by the occupancy calculator and the profiler. The following was the simplest program I could write that reproduces the behavior. The observed results are on my 8800 GTX. The program would almost definitely have to be altered to reproduce the behavior on a card with a different number of MP’s, but the modification needed may be as simple as changing NUM_BLOCKS_B to 2x the number of MPs you have, and possibly scaling NUM_BLOCKS_A appropriately (who knows).
[codebox]#include <stdio.h>
#define SAFE_CALL(call) do { \
cudaError_t err = call ; \
if(err != cudaSuccess) { \
   fprintf(stderr, "Cuda error in file '%s' in line %i : %s.\n", \
           __FILE__, __LINE__, cudaGetErrorString(err)); \
exit(1); \
} } while (0)
#define CHECK_ERROR() do { \
cudaError_t err = cudaGetLastError(); \
   fprintf(stderr, "Cuda error detected in file '%s' in line %i : %s.\n", \
exit(1); \
} } while (0)
#define NUM_BLOCKS_A 1700
#define NUM_THREADS_PER_BLOCK_A 1
#define NUM_BLOCKS_B 32
#define NUM_THREADS_PER_BLOCK_B 32
global void dumbkernel1() {
return;
shared unsigned int s[32];
global void occ_kernel(unsigned int* out) {
size_t overall_thread_index = threadIdx.x + blockIdx.x*(blockDim.x);
size_t i;
unsigned int val = 1;
s[0] = 1;
//do lots of dumb computation with lots of read after write dependencies so that different occupancies will have different runtimes
for(i = 0;i < 100000;++i) {
val = val + 3;
val = val*2;
val = val+ 5;
val = val*12;
out[overall_thread_index] = val;
int main() {
unsigned int* out;
SAFE_CALL(cudaMalloc((void**)(&out),NUM_BLOCKS_BNUM_THREADS_PER_BLOCK_Bsizeof(unsigne
d int)));
dim3 grid_dim_a,block_dim_a;
grid_dim_a.x = NUM_BLOCKS_A;
grid_dim_a.y = 1;
grid_dim_a.z = 1;
block_dim_a.x = NUM_THREADS_PER_BLOCK_A;
block_dim_a.y = 1;
block_dim_a.z = 1;
dim3 grid_dim_b,block_dim_b;
grid_dim_b.x = NUM_BLOCKS_B;
grid_dim_b.y = 1;
grid_dim_b.z = 1;
block_dim_b.x = NUM_THREADS_PER_BLOCK_B;
block_dim_b.y = 1;
block_dim_b.z = 1;
dumbkernel1<<<grid_dim_a,block_dim_a,13000>>>();
CHECK_ERROR();
SAFE_CALL(cudaThreadSynchronize());
dumbkernel1<<<grid_dim_a,block_dim_a>>>();
CHECK_ERROR();
//uncomment one of the following code blocks at a time and run to get the numbers I observed
/occupancy calculator and profiler say occupancy is 1 warp, profiler says runtime = 16207.456/
/*occ_kernel<<<grid_dim_b,block_dim_b,13000>>>(out);
CHECK_ERROR();
SAFE_CALL(cudaThreadSynchronize());*/
/occupancy calculator and profiler say occupancy is 2 warps, profiler says runtime = 8106.272/
/*occ_kernel<<<grid_dim_b,block_dim_b,5700>>>(out);
CHECK_ERROR();
/occupancy calculator and profiler say occupancy is 2 warps, profiler says runtime = 16207.456, so I think we’re really only getting 1 warp of occupancy/
/*occ_kernel<<<grid_dim_b,block_dim_b,6000>>>(out);
CHECK_ERROR();
printf(“done\n”);
return 0;
}[/codebox]
Edit: simplified program slightly and fixed bad grammar
