Occupancy Calc Data from cuDeviceGetAttribute
Hey there,
how can I obtain the values
    [*] Thread Blocks/Multiprocessor
    [*] Warps/Multiprocessor
from cuDeviceGetAttribute? These seem to be hardware limits that are given in the Occupancy Calculator, but I don’t see how they can be derived from the available attributes. (If they can’t, please take this as a suggestion to add them :) )
Andreas
For reference, this is what I get out of cuDeviceGetAttribute:
1 device(s) found.
Device #0: Quadro FX 570
 Â Compute Capability: 1.1
 Â Total Memory: 261440 KB
 Â CLOCK_RATE: 414000
 Â GPU_OVERLAP: 1
 Â MAX_BLOCK_DIM_X: 512
 Â MAX_BLOCK_DIM_Y: 512
 Â MAX_BLOCK_DIM_Z: 64
 Â MAX_GRID_DIM_X: 65535
 Â MAX_GRID_DIM_Y: 65535
 Â MAX_GRID_DIM_Z: 1
 Â MAX_PITCH: 262144
 Â MAX_REGISTERS_PER_BLOCK: 8192
 Â MAX_SHARED_MEMORY_PER_BLOCK: 16384
 Â MAX_THREADS_PER_BLOCK: 512
 Â MULTIPROCESSOR_COUNT: 2
 Â TEXTURE_ALIGNMENT: 256
 Â TOTAL_CONSTANT_MEMORY: 65536
 Â WARP_SIZE: 32
