Hi
I have a problem. I’m flashing binary using flash.sh script for the first time. below command
sudo ./flash.sh jetson-tx2 mmcblk0p1
And I could see “The target t186ref has been flashed successfully” log
But my tx2 board has kernel panic with follows logs.
What is problems. i flashed binary according to your quick start guide.
Plz tell me the reasons.
Thanks,
doohan93
[ 01:32:16 ] L4T initrd starts from here…
[ 01:32:16 ] L4T-INITRD Build DATE: Sat Jan 1 01:32:16 UTC 2000
[ 01:32:16 ] Root device found: mmcblk0p1
Rootdevice found: /dev/mmcblk0p1
[ 5.733913] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. O pts: (null)
[ 01:32:16 ] Rootfs mounted over mmcblk0p1
mount: mount point /mnt/proc does not exist
mount: mount point /mnt/sys does not exist
mount: mount point /mnt/dev does not exist
cp: cannot create regular file ‘etc/resolv.conf’: No such file or directory
[ 01:32:16 ] Switching from initrd to actual rootfs
chroot: failed to run command ‘/sbin/init’: No such file or directory
[ 5.780227] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00 007f00
[ 5.780227]
[ 5.791874] CPU3: stopping
[ 5.795412] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 4.4.15-tegra #1
[ 5.802686] Hardware name: quill (DT)
[ 5.807160] Call trace:
[ 5.810405] [] dump_backtrace+0x0/0x100
[ 5.816620] [] show_stack+0x14/0x1c
[ 5.822501] [] dump_stack+0x90/0xb4
[ 5.828372] [] handle_IPI+0x300/0x30c
[ 5.834394] [] gic_handle_irq+0x9c/0xb4
[ 5.840574] [] el1_irq+0x68/0xd8
[ 5.846142] [] cpuidle_enter+0x18/0x20
[ 5.852227] [] call_cpuidle+0x28/0x50
[ 5.858200] [] cpu_startup_entry+0x17c/0x340
[ 5.864772] [] secondary_start_kernel+0x130/0x168
[ 5.871766] [<000000008008192c>] 0x8008192c
[ 5.876650] CPU5: stopping
[ 5.880037] CPU: 5 PID: 0 Comm: swapper/5 Not tainted 4.4.15-tegra #1
[ 5.887158] Hardware name: quill (DT)
[ 5.891479] Call trace:
[ 5.894555] [] dump_backtrace+0x0/0x100
[ 5.900584] [] show_stack+0x14/0x1c
[ 5.906241] [] dump_stack+0x90/0xb4
[ 5.911867] [] handle_IPI+0x300/0x30c
[ 5.917644] [] gic_handle_irq+0x9c/0xb4
[ 5.923605] [] el1_irq+0x68/0xd8
[ 5.928962] [] cpuidle_enter+0x18/0x20
[ 5.934831] [] call_cpuidle+0x28/0x50
[ 5.940595] [] cpu_startup_entry+0x17c/0x340
[ 5.946972] [] secondary_start_kernel+0x130/0x168
[ 5.953779] [<000000008008192c>] 0x8008192c
[ 5.958501] CPU0: stopping
[ 5.961755] CPU: 0 PID: 0 Comm: swapper/0 Not tainted 4.4.15-tegra #1
[ 5.968770] Hardware name: quill (DT)
[ 5.973007] Call trace:
[ 5.976024] [] dump_backtrace+0x0/0x100
[ 5.982014] [] show_stack+0x14/0x1c
[ 5.987656] [] dump_stack+0x90/0xb4
[ 5.993288] [] handle_IPI+0x300/0x30c
[ 5.999089] [] gic_handle_irq+0x9c/0xb4
[ 6.005053] [] el1_irq+0x68/0xd8
[ 6.010407] [] cpuidle_enter+0x18/0x20
[ 6.016272] [] call_cpuidle+0x28/0x50
[ 6.022036] [] cpu_startup_entry+0x17c/0x340
[ 6.028416] [] rest_init+0x84/0x8c
[ 6.033915] [] start_kernel+0x39c/0x3b0
[ 6.039845] [<0000000080a63000>] 0x80a63000
[ 6.044574] CPU2: stopping
[ 6.047668] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 4.4.15-tegra #1
[ 6.054463] Hardware name: quill (DT)
[ 6.058484] Call trace:
[ 6.061296] [] dump_backtrace+0x0/0x100
[ 6.067062] [] show_stack+0x14/0x1c
[ 6.072478] [] dump_stack+0x90/0xb4
[ 6.077885] [] handle_IPI+0x300/0x30c
[ 6.083463] [] gic_handle_irq+0x9c/0xb4
[ 6.089211] [] el1_irq+0x68/0xd8
[ 6.094343] [] cpuidle_enter+0x18/0x20
[ 6.099991] [] call_cpuidle+0x28/0x50
[ 6.105548] [] cpu_startup_entry+0x17c/0x340
[ 6.111714] [] secondary_start_kernel+0x130/0x168
[ 6.118314] [<000000008008192c>] 0x8008192c
[ 6.122837] CPU1: stopping
[ 6.125902] CPU: 1 PID: 101 Comm: kworker/u12:3 Not tainted 4.4.15-tegra #1
[ 6.133221] Hardware name: quill (DT)
[ 6.137246] Workqueue: kmmcd mmc_rescan
[ 6.141453] Call trace:
[ 6.144260] [] dump_backtrace+0x0/0x100
[ 6.150028] [] show_stack+0x14/0x1c
[ 6.155448] [] dump_stack+0x90/0xb4
[ 6.160857] [] handle_IPI+0x300/0x30c
[ 6.166435] [] gic_handle_irq+0x9c/0xb4
[ 6.172193] [] el1_irq+0x68/0xd8
[ 6.177332] [] irq_exit+0x84/0xdc
[ 6.182552] [] __handle_domain_irq+0x6c/0xb4
[ 6.188728] [] gic_handle_irq+0x5c/0xb4
[ 6.194460] [] el1_irq+0x68/0xd8
[ 6.199585] [] sdhci_execute_tuning+0x33c/0x7bc
[ 6.206021] [] mmc_execute_tuning+0x40/0xb0
[ 6.212115] [] mmc_sdio_init_card+0x740/0x9e0
[ 6.218383] [] mmc_attach_sdio+0xa0/0x358
[ 6.224308] [] mmc_rescan+0x284/0x2f4
[ 6.229881] [] process_one_work+0x154/0x434
[ 6.235978] [] worker_thread+0x134/0x40c
[ 6.241812] [] kthread+0xe0/0xf4
[ 6.246949] [] ret_from_fork+0x10/0x40
[ 6.256798] Rebooting in 5 seconds…
