Can you show the ODMDdata bit definitions or documets which define them?
In Adaption Guide, ODMDDATA[31:27,24:22] are defined, but the other bits are not
defined.
Especially, I am looking for the way to configure the pcie C0 to endpoint mode.
So, it would be helpful to share the concerns of setting pcie C0 end point mode
on the Xavier DevKit.
As far as I know, pcie clock for the C0 is output to the M.2 card edge on Xavier
devkit even when it is at endpoint mode. My M.2 device can handle that, but I am
not sure PCIe C0 port in Xavier can work with that configuration.
- References
- Tegra_Linux_Driver_Package_AGX_Xavier_Adaptation_Guide.pdf
- Jetson_AGX_Xavier_OEM_Product_Design_Guide.pdf
- Jetson_AGX_Xavier_PCIe_Endpoint_Design_Guidelines.pdf
- Xavier_TRM_DP09253002.pdf
Thank you in avdance,
shino
