Oem-config cannot be skipped. What can I do
I created a user using a script based on the Nvidia official documentation to skip the oem-config configuration for the first boot, but I still couldn’t skip oem-config after I created a user and burned the boot.
我的脚本命令是
sudo su
cd Linux_for_Tegra/tools
bash l4t_create_default_user.sh -u my_user -p 123456 -a
cd ..
./apply_binaries.sh
你要先
sudo ./apply_binaries.sh
接著再
sudo ./tools/l4t_create_default_user.sh -u <username> -p <password> -a
才是對的
But I ran./apply_binaries.sh once before using l4t_create_default_user.sh, and once after using l4t_create_default_user.sh./apply_binaries. But still can’t skip oem-config. Is there a way to force skipping oem-config
你其實可以講中文就好,你上面那一段的英文我看不太懂…
請問你是哪一版的L4T?沒辦法跳過是開機還是會出現設定?
請你就整包BSP刪掉重來,先run apply_binaries.sh再run l4t_create_default_user.sh
没办法跳过,按照你的要求运行了l4t_create_default_user.sh和apply_binaries.sh,但是我是在l4t_create_default_user.sh前后都运行了一次apply_binaries.sh,这个有没有关系?
沒有人要你跑兩次apply_binaries.sh
請你就整包BSP刪掉再重來
Never run sudo apply_binaries.sh more than once. Only run sudo l4t_create_default_user.sh after apply_binaries.sh.
