the system got booteable and local engineer was able to connect local keyboard and display to the NX to open the initial configuration;
The only issue there was with headless oem-setup initiation on NX with OS from sdcard image. At the moment I couldn’t try the etcher. I will try with it later.
We tried dd method with latest sdcard image but don’t have any issue.
The question is whether the oem-setup works with the latest sdcard image distribution of the OS? Is it an issue specific to the image or to my setup? That is what I am trying to understand.
I am not sure if this is your setup or some special case that we cannot reproduce.
After you get failure, could you mount the SD card on PC and get the log from the /var/log/oem-config.log?
