I can’t properly install OFED 5.7 or 5.4 dirver on my system after I had installed intel i40e/ice driver.
I got the error message when I run [/etc/init.d/openibd restart] to load driver:
[root@localhost MLNX_OFED_LINUX-5.4-1.0.3.0-rhel8.4-x86_64]# /etc/init.d/openibd restart
Unloading auxiliary [FAILED]
rmmod: ERROR: Module auxiliary is in use by: ice
I found the reason is that the OFED dirver and i40e driver all have a module auxiliary installed, and the two “auxiliary.ko” is conflict.
/lib/modules/4.18.0-305.el8.x86_64/updates/drivers/net/ethernet/intel/auxiliary/auxiliary.ko
/lib/modules/4.18.0-305.el8.x86_64/extra/mlnx-ofa_kernel/drivers/base/auxiliary.ko
I tried the latest dirver and got the some result. Is there any fix or any proper way to use both driver/device ?
