Official CYPD4226 (Cypress PD controller) firmware for Jetson AGX Orin on Jetson Linux R39.2.1 / JetPack 7.2.1?
I am working on a custom carrier board based on the Jetson AGX Orin developer kit design (P3737 USB Type-C PD circuit with CYPD4226-40LQXI), and I would like to confirm which CYPD4226 firmware is the official one for current releases.
Environment:
  • Jetson Linux R39.2.1 (JetPack 7.2.1), Ubuntu 24.04 (Noble)
  • Kernel 6.8.12-1021-tegra, ucsi_ccg driver, UCSI 1.0.0
  • Board: AGX Orin developer kit-based design
What I found:
  • The JetPack 7.2.1 / Jetson Linux 39.2.1 download page has no CYPD4226 firmware in “Additional Files” (only the Customer IQ Migration Tools).
  • The only AGX Orin CYPD4226 firmware I could find is in the Jetson Linux 35.2.1 “Additional Files” section: CYPD4226-40LQXI_notebook.hex, CYPD4226-40LQXI_notebook_1.cyacd and CYPD4226-40LQXI_notebook_2.cyacd.(Link: R35 AGX Orin CYPD4226 firmware) The Jetson AGX Orin FAQ says it works with “any JetPack 5 version”, and does not mention JetPack 6 or 7.(Link: FAQ)
  • The Jetson Download Center has another entry, “Firmware binary for USB Type-C PD controller used on Jetson AGX Xavier Developer Kit” (version 12.05, 2019/04/12). From earlier forum replies I understand that the Xavier firmware is not supported on Orin.
  • The Jetson AGX Orin Series Design Guide (DG-10653-001 v1.81) says the firmware binary is available on the Jetson Download Center, and that designs must replicate the reference circuit exactly.
Questions:
  1. For AGX Orin on R39.2.1 / JetPack 7.2.1, is the CYPD4226-40LQXI_notebook firmware from the R35.2.1 “Additional Files” still the latest official firmware? If a newer build exists, could you share the official link?
  2. Is the R35.2.1 firmware validated for use with R36/R39 (kernel 6.8, ucsi_ccg)?
  3. What firmware version is programmed into the CYPD4226 on the AGX Orin developer kit at shipment, and is it identical to the R35.2.1 files?
  4. Could the R39.2.1 download page and the design guide be updated to point to the correct CYPD4226 firmware, so that users of current releases do not have to look for it in the R35 documentation?
Thank you for your help.
Regards.
That firmware has nothing to do rel-35/rel36/rel39. It could still work .
