It starts as per the instructions and then on step 9, nothing works, I tried pretty much every option and setting available, no luck. I keep getting “CLIPTextEncode error”. I tried doing the clean up and following the instructions again to make sure I did everything right. That includes also the "Z-Image-Turbo: Text to Image", suggested as a test template.
I wonder, isn’t NVIDIA not even checking their own documentation ? I Bought the DGX Spark specifically because it was supposed to be supported and just do the job, if I want to hack around I would have gotten something better. That’s a shame.
That’s a rough first experience, on a brand new box. :D
A CLIPTextEncode error usually means the text encoder didn’t load the way the workflow expects. The usual causes are a wrong or missing text encoder file for the model, or a ComfyUI build that is older than the template. If you can paste the full traceback from the terminal (not just the red box in the UI), people here can usually pin it down quickly… anyhow, if you’d rather skip the manual setup: a number of us here have been building spark-comfyui. It’s one script that installs, runs and updates ComfyUI on the Spark in a container, with the GB10-specific parts (cu130 PyTorch, native sm_121 SageAttention, the known stability tweaks) already baked in:
git clone https://github.com/bjarkebolding/spark-comfyui.git
cd spark-comfyui
./spark-comfyui.sh install # one-time build, ~5 min
./spark-comfyui.sh tune --persist # recommended host tweaks
./spark-comfyui.sh run # UI at http://<spark-ip>:8188
If anything misbehaves, ./spark-comfyui.sh doctor checks the whole GPU stack and tells you what to fix. It doesn’t touch your system Python, and your models and workflows live in a plain data/ folder. Stop the playbook’s ComfyUI first so port 8188 is free.
