Official TensorFlow for Jetson Nano!
when I run a code that import tensorflow library I get an error related to the system power, kindly check this inquiry
I installed Tensorflow 2 on Jetson Nano, Jetpack 4.6 according to the above documented instructions. The installation went successfully, but if I want to import it in python3, the following error message appears:
wib@nano:~$ python3
Python 3.6.9 (default, Jan 26 2021, 15:33:00)
[GCC 8.4.0] on linux
Type β€œhelp”, β€œcopyright”, β€œcredits” or β€œlicense” for more information.
import tensorflow as tf
Illegal instruction (core dumped)
wib@nano:~$
Same problem happens with other subsystems, e.g. numpy.
Normal python instructions are proper processed.
Any idea to repair this import issue?
Many thanks in advance
Walter
I have been trying to cross compile python wheel tensorflow lite for Jetson nano device.
referring following link:
ARM cross compilation
tensorflow/tools/ci_build/ci_build.sh PI-PYTHON38 \ tensorflow/lite/tools/pip_package/build_pip_package_with_cmake.sh aarch6
But soon after compilation starts, at around 20 minutes, my screen freeze, I had to shutdown my device, Do i need to make any changes before starting compilation.
Environment
Host device : Ubuntu 20.04 LTS
Steps To Reproduce
1. git clone https://github.com/tensorflow/tensorflow.git tensorflow_src
2. tensorflow/tools/ci_build/ci_build.sh PI-PYTHON38 \  tensorflow/lite/tools/pip_package/build_pip_package_with_cmake.sh aarch6
try to execute this command export OPENBLAS_CORETYPE=ARMV8 before you run your python code
@Noctis command export OPENBLAS_CORETYPE=ARMV8 did not work.
Has gotten gpu support this installation?. Thanx.
I have a quick question.
Does this official release of TensorFlow for Jetson Nano make use of CUDA cores? Or does it run on CPU?
If I were using the same model, what would be faster? TensorRT or TensorFlow?
Could I apply this to Jetson nx?
Could you provide a TensorFlow 2.5 whl for Jetpack 4.6.1 & 4.6.2
We need it to export our model and generate the onnx model for TFOD
Your help is very appreciated
Yeah, agree with Kamal, WHAT ABOUT AN UPDATE FOR NANOs???
I’ve been trying to get this running for almost 2 months, so now I’m going to ask here.
Env details:
Python 3.8, Jetpack 4.6.3, Jetson Nano, Cuda 10.2.3, L4T 32.7.3, cuDNN 8.2.1.32
Up until yesterday, I’ve been locked in a state where I had Tensorflow installed and β€˜working’. Each time if I asked Tensorflow if there was a GPU, such as here: Tensorflow not using GPU of Jetson nano - #2 by ALEEF02, it would report not. Thus, all my processing times were incredibly slow. From the above thread, I tried adding the following lines to my .bashrc:
export LD_LIBRARY_PATH=/usr/local/cuda/lib64:$LD_LIBRARY_PATH
export PATH=/usr/local/cuda/bin:$PATH
Now, Tensorflow cannot find Cuda. It tries to open libcudart.so.11.0, but fails, since Jetpack 4.6.3 has Cuda 10.2. I’ve tried removing those lines from the .bashrc, source, reboot, but it’s still failing. I’ve tried reinstalling tensorflow, but I still get the same issue.
2 interesting notes on the reinstall.
A) I was using tensorflow-2.11.0+nv23.1 from https://developer.download.nvidia.com/compute/redist/jp/v51/tensorflow originally and didn’t even notice. How was that even working beforehand, since I’m on Jetpack 4.6.3?? I got Tensorflow to run using the JP5.1 version, but only on the CPU - but, regardless, it still ran and interpreted.
B) I tried installing the Jetpack 46 version (tensorflow-2.7.0+nv22.1) from Index of /compute/redist/jp/v46, but it fails since ...is not a supported wheel on this platform. What?? Am I not on Jetpack 4.6.3? I swear I am - especially since the Nano doesn’t support Jetpack 5(?)
What am I to do in this situation? I really need Tensorflow to run on the Jetson Nano’s integrated GPU, and soon! I am willing to upload a log of everything I’ve tried so far, as I’ve been noting it down. Any advice is appreciated, even if that includes reflashing.
Regards,
Anthony
hi, I follow the next steps to install tesnorflow:
Python 3.6+JetPack4.6.3
$ sudo apt-get update
$ sudo apt-get install -y libhdf5-serial-dev hdf5-tools libhdf5-dev zlib1g-dev zip libjpeg8-dev liblapack-dev libblas-dev gfortran
$ sudo ln -s /usr/include/locale.h /usr/include/xlocale.h
$ sudo pip3 install --verbose 'protobuf<4' 'Cython<3'
$ sudo wget --no-check-certificate https://developer.download.nvidia.com/compute/redist/jp/v461/tensorflow/tensorflow-2.7.0+nv22.1-cp36-cp36m-linux_aarch64.whl
$ sudo pip3 install --verbose tensorflow-2.7.0+nv22.1-cp36-cp36m-linux_aarch64.whl
First i have python 3.6.9 and Jetpack 4.6.4, so in theory, that steps will work but i get an error when i execute sudo pip3 install --verbose tensorflow-2.7.0+nv22.1-cp36-cp36m-linux_aarch64.whl
Looking up "https://files.pythonhosted.org/packages/6c/be/4e32d02bf08b8f76bf6e59f2a531690c1e4264530404501f3489ca975d9a/protobuf-4.21.0-py2.py3-none-any.whl" in the cache
  No cache entry available
  https://files.pythonhosted.org:443 "GET /packages/6c/be/4e32d02bf08b8f76bf6e59f2a531690c1e4264530404501f3489ca975d9a/protobuf-4.21.0-py2.py3-none-any.whl HTTP/1.1" 200 164995
  Downloading https://files.pythonhosted.org/packages/6c/be/4e32d02bf08b8f76bf6e59f2a531690c1e4264530404501f3489ca975d9a/protobuf-4.21.0-py2.py3-none-any.whl (164kB)
  Downloading from URL https://files.pythonhosted.org/packages/6c/be/4e32d02bf08b8f76bf6e59f2a531690c1e4264530404501f3489ca975d9a/protobuf-4.21.0-py2.py3-none-any.whl#sha256=14c5fa41122e270d815b954ecdc25cb107d44b7d039def5cc57a5e5a9ab8d741 (from https://pypi.org/simple/protobuf/)
    99% |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–Š| 163kB 22.0MB/s eta 0:00:01  Updating cache with response from "https://files.pythonhosted.org/packages/6c/be/4e32d02bf08b8f76bf6e59f2a531690c1e4264530404501f3489ca975d9a/protobuf-4.21.0-py2.py3-none-any.whl"
  Caching due to etag
    100% |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 174kB 2.6MB/s
Cleaning up...
  Removing source in /tmp/pip-build-jtggmfa5/numpy
  Removing source in /tmp/pip-build-jtggmfa5/h5py
  Removing source in /tmp/pip-build-jtggmfa5/termcolor
protobuf requires Python '>=3.7' but the running Python is 3.6.9
Exception information:
  File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 342, in run
    requirement_set.prepare_files(finder)
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 666, in _prepare_file
    check_dist_requires_python(dist)
  File "/usr/lib/python3/dist-packages/pip/utils/packaging.py", line 57, in check_dist_requires_python
    '.'.join(map(str, sys.version_info[:3])),)
pip.exceptions.UnsupportedPythonVersion: protobuf requires Python '>=3.7' but the running Python is 3.6.9
why does it ask me to have a major version of python?
Hi Andradealejandroc
try and upgrade you’re pip
python3 -m pip install --upgrade pip
then do the install again
here is my output running the exact same commands except i’ve upgraded pip
Successfully installed absl-py-0.12.0 astunparse-1.6.3 cached-property-1.5.2 cachetools-4.2.4 charset-normalizer-2.0.12 clang-5.0 dataclasses-0.8 flatbuffers-1.12 gast-0.4.0 google-auth-2.22.0 google-auth-oauthlib-0.4.6 google-pasta-0.2.0 grpcio-1.48.2 h5py-3.1.0 importlib-metadata-4.8.3 keras-2.10.0 keras-preprocessing-1.1.2 markdown-3.3.7 numpy-1.19.5 oauthlib-3.2.2 opt-einsum-3.3.0 protobuf-3.19.6 pyasn1-0.5.0 pyasn1-modules-0.3.0 requests-2.27.1 requests-oauthlib-1.3.1 rsa-4.9 setuptools-59.6.0 six-1.16.0 tensorboard-2.10.1 tensorboard-data-server-0.6.1 tensorboard-plugin-wit-1.8.1 tensorflow-2.7.0+nv22.1 tensorflow-estimator-2.8.0 termcolor-1.1.0 typing-extensions-4.1.1 werkzeug-2.0.3 wheel-0.37.1 wrapt-1.15.0 zipp-3.6.0
Yes !
Upgrading PIP makes the installation work for the JetPack 4.6.4, with Python 3.6 on the Jetson Nano (mine is 4GB)
I have the same problem as mentioned in the last question by feiticeir0]
I upgraded pip to the latest version 22.1.3 and tried to run:
However, I get this error:
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
WARNING: The directory '/home/bornak/.cache/pip' or its parent directory is not owned or is not writable by the current user. The cache has been disabled. Check the permissions and owner of that directory. If executing pip with sudo, you should use sudo's -H flag.
Using pip 21.3.1 from /home/bornak/.local/lib/python3.6/site-packages/pip (python 3.6)
Requirement already satisfied: protobuf<4 in /usr/local/lib/python3.6/dist-packages (3.19.6)
Requirement already satisfied: Cython<3 in /usr/local/lib/python3.6/dist-packages (0.29.37)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/9f/8b/a094f5da22d7abf5098205367b3296dd15b914f4232af5ca39ba6214d08c/pip-22.0-py3-none-any.whl#sha256=6cb1ea2bd7fda0668e26ae8c3e45188f301a7ef17ff22efe1f70f3643e56a822 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/4a/ca/e72b3b399d7a8cb34311aa8f52924108591c013b09f0268820afb4cd96fb/pip-22.0.tar.gz#sha256=d3fa5c3e42b33de52bddce89de40268c9a263cd6ef7c94c40774808dafb32c82 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/89/a1/2f4e58eda11e591fbfa518233378835679fc5ab766b690b3df85215014d5/pip-22.0.1-py3-none-any.whl#sha256=30739ac5fb973cfa4399b0afff0523d4fe6bed2f7a5229333f64d9c2ce0d1933 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/63/71/5686e51f06fa59da55f7e81c3101844e57434a30f4a0d7456674d1459841/pip-22.0.1.tar.gz#sha256=7fd7a92f2fb1d2ac2ae8c72fb10b1e640560a0361ed4427453509e2bcc18605b (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/83/b5/df8640236faa5a3cb80bfafd68e9fb4b22578208b8398c032ccff803f9e0/pip-22.0.2-py3-none-any.whl#sha256=682eabc4716bfce606aca8dab488e9c7b58b0737e9001004eb858cdafcd8dbdd (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/d9/c1/146b24a7648fdf3f8b4dc6521ab0b26ac151ef903bac0b63a4e1450cb4d1/pip-22.0.2.tar.gz#sha256=27b4b70c34ec35f77947f777070d8331adbb1e444842e98e7150c288dc0caea4 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/6a/df/a6ef77a6574781a668791419ffe366c8acd1c3cf4709d210cb53cd5ce1c2/pip-22.0.3-py3-none-any.whl#sha256=c146f331f0805c77017c6bb9740cec4a49a0d4582d0c3cc8244b057f83eca359 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/88/d9/761f0b1e0551a3559afe4d34bd9bf68fc8de3292363b3775dda39b62ce84/pip-22.0.3.tar.gz#sha256=f29d589df8c8ab99c060e68ad294c4a9ed896624f6368c5349d70aa581b333d0 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/4d/16/0a14ca596f30316efd412a60bdfac02a7259bf8673d4d917dc60b9a21812/pip-22.0.4-py3-none-any.whl#sha256=c6aca0f2f081363f689f041d90dab2a07a9a07fb840284db2218117a52da800b (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/33/c9/e2164122d365d8f823213a53970fa3005eb16218edcfc56ca24cb6deba2b/pip-22.0.4.tar.gz#sha256=b3a9de2c6ef801e9247d1527a4b16f92f2cc141cd1489f3fffaf6a9e96729764 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/79/3a/d341ae105c8b49eac912bee40739d496ae80f9441efa7df6c68f4997bbc8/pip-22.1b1-py3-none-any.whl#sha256=09e9e8f8e10f2515134b59600ad3630219430eabb734336079cbc6ffb2e01a0e (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/a7/c0/794f22836ef3202a7ad61f0872278ee7ac62e8c7617e4c9a08f01b5e82da/pip-22.1b1.tar.gz#sha256=f54ab61985754b56c5589178cfd7dfca5ed9f98d5c8f2de2eecb29f1341200f1 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/f3/77/23152f90de45957b59591c34dcb39b78194eb67d088d4f8799e9aa9726c4/pip-22.1-py3-none-any.whl#sha256=802e797fb741be1c2d475533d4ea951957e4940091422bd4a24848a7ac95609d (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/99/bb/696e256f4f445809f25efd4e4ce42ff99664dc089cafa1e097d5fec7fc33/pip-22.1.tar.gz#sha256=2debf847016cfe643fa1512e2d781d3ca9e5c878ba0652583842d50cc2bcc605 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/9b/e6/aa8149e048eda381f2a433599be9b1f5e5e3a189636cd6cf9614aa2ff5be/pip-22.1.1-py3-none-any.whl#sha256=e7bcf0b2cbdec2af84cc1b7b79b25fdbd7228fbdb61a4dca0b82810d0ba9d18b (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/3e/0a/6125e67aa4d3245faeed476e4e26f190b5209f84f01efd733ac6372eb247/pip-22.1.1.tar.gz#sha256=8dfb15d8a1c3d3085a4cbe11f29e19527dfaf2ba99354326fd62cec013eaee81 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/96/2f/caec18213f6a67852f6997fb0673ae08d2e93d1b81573edb93ba4ef06970/pip-22.1.2-py3-none-any.whl#sha256=a3edacb89022ef5258bf61852728bf866632a394da837ca49eb4303635835f17 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/4b/b6/0fa7aa968a9fa4ef63a51b3ff0644e59f49dcd7235b3fd6cceb23f202e08/pip-22.1.2.tar.gz#sha256=6d55b27e10f506312894a87ccc59f280136bad9061719fac9101bdad5a6bce69 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/9b/9e/9e0610f25e65e2cdf90b1ee9c47ca710865401904038558ac0129ea23cbc/pip-22.2-py3-none-any.whl#sha256=9abf423d5d64f3289ab9d5bf31da9e6234f2e9c5d8dcf1423bcb46b809a02c2c (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/cd/b6/cf07132d631444dd7ce0ed199f2327eb34e2418f1675145e5b10e1ee65cd/pip-22.2.tar.gz#sha256=8d63fcd4ee293e30b644827268a0a973d080e5c7425ef26d427f5eb2126c7681 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/84/25/5734a44897751d8bac6822efb819acda2d969bcc1b915bbd7d48102952cb/pip-22.2.1-py3-none-any.whl#sha256=0bbbc87dfbe6eed217beff0021f8b7dea04c8f4a0baa9d31dc4cff281ffc5b2b (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/46/28/addd7e66bb3af799d35a5dcbb79407b591a7ed674f4efd2bd8f930c40821/pip-22.2.1.tar.gz#sha256=50516e47a2b79e77446f0d05649f0d53772c192571486236b1905492bfc24bac (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/1f/2c/d9626f045e7b49a6225c6b09257861f24da78f4e5f23af2ddbdf852c99b8/pip-22.2.2-py3-none-any.whl#sha256=b61a374b5bc40a6e982426aede40c9b5a08ff20e640f5b56977f4f91fed1e39a (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/4b/30/e15b806597e67057e07a5acdc135216ccbf76a5f1681a324533b61066b0b/pip-22.2.2.tar.gz#sha256=3fd1929db052f056d7a998439176d3333fa1b3f6c1ad881de1885c0717608a4b (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/47/ef/8b5470b5b94b36231ed9c0bde90caa71c0d4322d4a15f009b2b7f4287fe0/pip-22.3-py3-none-any.whl#sha256=1daab4b8d3b97d1d763caeb01a4640a2250a0ea899e257b1e44b9eded91e15ab (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/f8/08/7f92782ff571c7c7cb6c5eeb8ebbb1f68cb02bdb24e55c5de4dd9ce98bc3/pip-22.3.tar.gz#sha256=8182aec21dad6c0a49a2a3d121a87cd524b950e0b6092b181625f07ebdde7530 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/09/bd/2410905c76ee14c62baf69e3f4aa780226c1bbfc9485731ad018e35b0cb5/pip-22.3.1-py3-none-any.whl#sha256=908c78e6bc29b676ede1c4d57981d490cb892eb45cd8c214ab6298125119e077 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/a3/50/c4d2727b99052780aad92c7297465af5fe6eec2dbae490aa9763273ffdc1/pip-22.3.1.tar.gz#sha256=65fd48317359f3af8e593943e6ae1506b66325085ea64b706a998c6e83eeaf38 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/ab/43/508c403c38eeaa5fc86516eb13bb470ce77601b6d2bbcdb16e26328d0a15/pip-23.0-py3-none-any.whl#sha256=b5f88adff801f5ef052bcdef3daa31b55eb67b0fccd6d0106c206fa248e0463c (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/b5/16/5e24bf63cff51dcc169f43bd43b86b005c49941e09cc3482a5b370db239e/pip-23.0.tar.gz#sha256=aee438284e82c8def684b0bcc50b1f6ed5e941af97fa940e83e2e8ef1a59da9b (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/07/51/2c0959c5adf988c44d9e1e0d940f5b074516ecc87e96b1af25f59de9ba38/pip-23.0.1-py3-none-any.whl#sha256=236bcb61156d76c4b8a05821b988c7b8c35bf0da28a4b614e8d6ab5212c25c6f (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/6b/8b/0b16094553ecc680e43ded8f920c3873b01b1da79a54274c98f08cb29fca/pip-23.0.1.tar.gz#sha256=cd015ea1bfb0fcef59d8a286c1f8bebcb983f6317719d415dc5351efb7cd7024 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/ae/db/a8821cdac455a1740580c92de3ed7b7f257cfdbad8b1ba8864e6abe58a08/pip-23.1-py3-none-any.whl#sha256=64b1d4528e491aa835ec6ece0c1ac40ce6ab6d886e60740f6519db44b2e9634d (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/da/bf/1bdbe62f5fbde085351693e3a8e387a59f8220932b911b1719fe65efa2d7/pip-23.1.tar.gz#sha256=408539897ee535dbfb83a153f7bc4d620f990d8bd44a52a986efc0b4d330d34a (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/f8/f8/17bd3f7c13515523d811ce4104410c16c03e3c6830f9276612e2f4b28382/pip-23.1.1-py3-none-any.whl#sha256=3d8d72fa0714e93c9d3c2a0ede91e898c64596e0fa7d4523f72dd95728efc418 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/43/7d/1f52f99a7f2eae870483b2c2a3064511487de87911bce146df8a154fbe81/pip-23.1.1.tar.gz#sha256=c95b53d309f903f33dfe5fd37e502a5c3a05ee3454d518e45df522a4f091b728 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/08/e3/57d4c24a050aa0bcca46b2920bff40847db79535dc78141eb83581a52eb8/pip-23.1.2-py3-none-any.whl#sha256=3ef6ac33239e4027d9a5598a381b9d30880a1477e50039db2eac6e8a8f6d1b18 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/fa/ee/74ff76da0ab649eec7581233daeb43d8aa35383d8f75317b2ab3b80c922f/pip-23.1.2.tar.gz#sha256=0e7c86f486935893c708287b30bd050a36ac827ec7fe5e43fe7cb198dd835fba (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/02/65/f15431ddee78562355ccb39097bf9160a1689f2db40dc418754be98806a1/pip-23.2-py3-none-any.whl#sha256=78e5353a9dda374b462f2054f83a7b63f3f065c98236a68361845c1b0ee7e35f (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/3d/ab/21fa8d1ecf5648559f056fda732b0f9fca0585eb2688252e67f70e74deaf/pip-23.2.tar.gz#sha256=a160a170f3331d9ca1a0247eb1cd79c758879f1f81158f9cd05bbb5df80bea5c (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/50/c2/e06851e8cc28dcad7c155f4753da8833ac06a5c704c109313b8d5a62968a/pip-23.2.1-py3-none-any.whl#sha256=7ccf472345f20d35bdc9d1841ff5f313260c2c33fe417f48c30ac46cccabf5be (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/ba/19/e63fb4e0d20e48bd2167bb7e857abc0e21679e24805ba921a224df8977c0/pip-23.2.1.tar.gz#sha256=fb0bd5435b3200c602b5bf61d2d43c2f13c02e29c1707567ae7fbc514eb9faf2 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/e0/63/b428aaca15fcd98c39b07ca7149e24bc14205ad0f1c80ba2b01835aedde1/pip-23.3-py3-none-any.whl#sha256=bc38bb52bc286514f8f7cb3a1ba5ed100b76aaef29b521d48574329331c5ae7b (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/0d/f6/07ef4561bb911285c229fa46ed3df1877bd6c5325c4c67d516560d59a6e6/pip-23.3.tar.gz#sha256=bb7d4f69f488432e4e96394612f43ab43dd478d073ef7422604a570f7157561e (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/47/6a/453160888fab7c6a432a6e25f8afe6256d0d9f2cbd25971021da6491d899/pip-23.3.1-py3-none-any.whl#sha256=55eb67bb6171d37447e82213be585b75fe2b12b359e993773aca4de9247a052b (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/1f/7f/4da15e07ccd11c84c1ccc8f6e24288d5e76c99441bf80e315b33542db951/pip-23.3.1.tar.gz#sha256=1fcaa041308d01f14575f6d0d2ea4b75a3e2871fe4f9c694976f908768e14174 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/15/aa/3f4c7bcee2057a76562a5b33ecbd199be08cdb4443a02e26bd2c3cf6fc39/pip-23.3.2-py3-none-any.whl#sha256=5052d7889c1f9d05224cd41741acb7c5d6fa735ab34e339624a614eaaa7e7d76 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/b7/06/6b1ad0ae8f97d7a0d6f6ad640db10780578999e647a9593512ceb6f06469/pip-23.3.2.tar.gz#sha256=7fd9972f96db22c8077a1ee2691b172c8089b17a5652a44494a9ecb0d78f9149 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/8a/6a/19e9fe04fca059ccf770861c7d5721ab4c2aebc539889e97c7977528a53b/pip-24.0-py3-none-any.whl#sha256=ba0d021a166865d2265246961bec0152ff124de910c5cc39f1156ce3fa7c69dc (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
  Link requires a different Python (3.6.9 not in: '>=3.7'): https://files.pythonhosted.org/packages/94/59/6638090c25e9bc4ce0c42817b5a234e183872a1129735a9330c472cc2056/pip-24.0.tar.gz#sha256=ea9bd1a847e8c5774a5777bb398c19e80bcd4e2aa16a4b301b718fe6f593aba2 (from https://pypi.org/simple/pip/) (requires-python:>=3.7)
after trying to run:
I get this error: (I did not copy all the logs here only the logs at the end are copied here)
  Attempting uninstall: setuptools
    Found existing installation: setuptools 39.0.1
    Uninstalling setuptools-39.0.1:
      Removing file or directory /usr/lib/python3/dist-packages/__pycache__/easy_install.cpython-36.pyc
      Removing file or directory /usr/lib/python3/dist-packages/easy_install.py
      Removing file or directory /usr/lib/python3/dist-packages/pkg_resources
      Removing file or directory /usr/lib/python3/dist-packages/setuptools
      Removing file or directory /usr/lib/python3/dist-packages/setuptools-39.0.1.egg-info
      Successfully uninstalled setuptools-39.0.1
  Attempting uninstall: protobuf
    Found existing installation: protobuf 3.0.0
    Uninstalling protobuf-3.0.0:
      Removing file or directory /usr/lib/python3/dist-packages/protobuf-3.0.0.egg-info
      Successfully uninstalled protobuf-3.0.0
  Attempting uninstall: numpy
    Found existing installation: numpy 1.13.3
    Uninstalling numpy-1.13.3:
      Removing file or directory /usr/lib/python3/dist-packages/numpy
      Removing file or directory /usr/lib/python3/dist-packages/numpy-1.13.3.egg-info
      Successfully uninstalled numpy-1.13.3
  changing mode of /usr/local/bin/f2py to 755
  changing mode of /usr/local/bin/f2py3 to 755
  changing mode of /usr/local/bin/f2py3.6 to 755
  changing mode of /usr/local/bin/markdown_py to 755
  changing mode of /usr/local/bin/google-oauthlib-tool to 755
  changing mode of /usr/local/bin/tensorboard to 755
  changing mode of /usr/local/bin/estimator_ckpt_converter to 755
  changing mode of /usr/local/bin/import_pb_to_tensorboard to 755
  changing mode of /usr/local/bin/saved_model_cli to 755
  changing mode of /usr/local/bin/tf_upgrade_v2 to 755
  changing mode of /usr/local/bin/tflite_convert to 755
  changing mode of /usr/local/bin/toco to 755
  changing mode of /usr/local/bin/toco_from_protos to 755
ERROR: pip's dependency resolver does not currently take into account all the packages that are installed. This behaviour is the source of the following dependency conflicts.
launchpadlib 1.10.6 requires testresources, which is not installed.
Successfully installed absl-py-0.12.0 astunparse-1.6.3 cached-property-1.5.2 cachetools-4.2.4 charset-normalizer-2.0.12 clang-5.0 dataclasses-0.8 flatbuffers-1.12 gast-0.4.0 google-auth-2.22.0 google-auth-oauthlib-0.4.6 google-pasta-0.2.0 grpcio-1.48.2 h5py-3.1.0 importlib-metadata-4.8.3 keras-2.10.0 keras-preprocessing-1.1.2 markdown-3.3.7 numpy-1.19.5 oauthlib-3.2.2 opt-einsum-3.3.0 protobuf-3.19.6 pyasn1-0.5.1 pyasn1-modules-0.3.0 requests-2.27.1 requests-oauthlib-1.3.1 rsa-4.9 setuptools-59.6.0 six-1.16.0 tensorboard-2.10.1 tensorboard-data-server-0.6.1 tensorboard-plugin-wit-1.8.1 tensorflow-2.7.0+nv22.1 tensorflow-estimator-2.8.0 termcolor-1.1.0 typing-extensions-4.1.1 werkzeug-2.0.3 wheel-0.37.1 wrapt-1.16.0 zipp-3.6.0
I am not able to install the h5py package although I am not even providing the version. Following is the error message "ERROR: Failed building wheel for h5py
Failed to build h5py
ERROR: Could not build wheels for h5py, which is required to install pyproject.toml-based projects
